05-21-2012, 16:11 | #1 (permalink) |
Junior Member Join Date: Dec 2011
Member: 1701344 Status: Offline Sonork: FIXSTATION Thanks Meter: 19 | iPhone 4g Vibrator - No power The vibrator does not work at all. Things i just tried. 1. replaced the flex cable (vibrator switch + volume) - still doesn't work 2. soft reset + hard reset - still doesn't work 3. Test new vibrator x 5 - still doesn't work Now i believe it a logicboard issues where there is no power source going through this section. Any idea where i might be able to fix this? I got a circuit pen and were able to fix the front camera by bridging two points together. Hope this incident are the same case. Fixstation. |
05-22-2012, 13:24 | #5 (permalink) |
Member: 1701344 Status: Offline Sonork: FIXSTATION Thanks Meter: 19 | Ok I used the circuit pen to fix up the front camera fuses. This work perfect. But how the heck do should i approach these fuses? The pen tip is to big. I mean what do all the pro technician use to solder these connect / fuses together? Fair enough a microscope help you see.. is there a micro soldering iron? I'm scared to put the lead liquid and short circuit all the other component. Need expert advice. |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Dejans Flasher Problem with 6150, NO Network after Flashing | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-03-2001 22:39 |
My 6150 (5.23) No network after Flashing | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-31-2001 15:56 |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
