03-30-2013, 06:16 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: tamilnadu Age: 41
Member: 354610 Status: Offline Thanks Meter: 12 | iphone 4s ACTIVATION REQUIRED iphone 4s a1387 provider o2 v6.0.1 when i insert sim card showing signal but shows ACTIVATION REQUIRED i tried activate via in wifi but shows this error (ONLY COMPATIBLE SIMCARDS FROM A SUPPORTED CARRIER MAY BE USED TO ACTIVATE IPHONE PLEASE INSERT THE SIM CARD THAT COME WITH UR IPHONE OR VISIT A SUPPORTED CARRIERS STORE TO RECIVE A REPLACEMENT SIMCARD) I ALSO TRIED VIA ITUNES THE ERROR SHOWS LIKE THIS Then i tried to jailbreak the phone using redsn0w_win_0.9.15b3 shows unsupported ipsw while i select ipsw v6.0 file I also tried in evasi0n like below steps Step 1. The first thing you need to do is go to Cydia and install SAM. All you need to do is go to 'Cydia' then 'Manage' and then 'Sources' and at the top right corner press the edit option and enter: http://repo.bingner.com Step 2. After you have installed SAM, you will be able to see it on your Springboard. Press SAM to launch it. However, you need to make sure that you have the SIM card which you want to use in your iPhone. SAM - 4.11.08 unlock Step 3. After you have entered SAM, navigate to utilities and then select 'De-Activate iPhone'. The ActivationState under 'More Infromation' will now be inactivated. Unlock 4.11.08 baseband Step 4. Once, SAM has been enabled, go to 'By Country and Carrier' present in 'Method' and then select your carrier. You might need to select the 'SIM ID' for carriers operating with more than one Carrier ID. This is easy for you to figure out when you notice that iTunes will not activate if the wrong IMSI has been selected. Step 4 Unlock iPhone 4 baseband 4.11.08 Step 5. Navigate your way to 'More Information' and write down or copy the IMSI in the 'SAM Details' and then tap the option, 'Spoof Real SIM to SAM'. Step 6. Now, go back to the main screen of SAM and then change the 'Method' to manual. Now, enter or paste the IMSI string which was saved during step 5th. Step 7. Using iTunes connect your iPhone to the computer in order to reactivate your device. Simply double tap the 'Phone Number' present at the main screen of the device in order to make sure the ICCID matches with the one present on your SIM card. If the match isn't exact, you'll need to again start from step 1. Step 8. Now, close iTunes and then unplug the iPhone 4 and disable SAM. Step 9. Again connect the iPhone 4 to iTunes and you will see a message telling you that it can't be activated. Close it and open it again. Step 10. The signal bars lets you know that the iPhone 4 baseband 4.11.08 has been unlocked. Experts plz help me Thanks in advance |
03-30-2013, 13:36 | #3 (permalink) | |
No Life Poster Join Date: Mar 2013 Location: pakistan Age: 34
Member: 1899191 Status: Offline Sonork: 100.1625109 Thanks Meter: 136 | Quote:
