10-11-2013, 14:24 | #1 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2042640 Status: Offline Thanks Meter: 0 | Iphone 4s blocked on waiting iphone on itunes My 4s after sudden shutdown is blocked in dfu. I try to restore ios 7.0.2 and now itunes is blocked on waiting for iphone and the device on apple icon with gray charging bar and this status remains also when i disconnect usb...it's bricked? How can i fix it? |
10-20-2013, 13:26 | #4 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1493666 Status: Offline Sonork: hai Thanks Meter: 4 | its not a hard ware problem........its s/w fault...downlode latest version of itune and moborobo and istall it....cnnect your cable on the same port as you used to flash other phones... now open itunes and connect your phone ...when you connet your iphone moborobo will appear click launch and itunes also recoganise your iphone restore it manually by pressing shift and click in restore same time a window will appear select your firmware and press ok now press refresh button on moborobo until the restoring complete its done i tested this in iphone 5 i got error msg(2003,4003,4015,7,4,1) but after i done as i said its ok still it does not work change cable,computer,different os (xp.win7,win8) and wait for one day |
05-12-2014, 17:07 | #6 (permalink) | |
Junior Member Join Date: Aug 2010 Location: London, United Kingdom Age: 40
Member: 1361021 Status: Offline Thanks Meter: 24 | Quote:
Start your restore and wait until you see "waiting for iPhone in iTunes" dont close iTunes and don't disconnect the iPhone, but put it in DFU mode right there, then it should restore normally. This is not a sure method, because i don't remember it right It may be this method or a slight variation of it The problem is with iTunes putting the iPhone into an unrecognizable state | |
