Old 06-01-2015, 08:17   #1 (permalink)
bipugunjan's Avatar
Member: 526223
Sonork: 100.1605395
Thanks Meter: 106
iphone 4s 48 error
iPhone 4s 48 error try to update 7.0.4 to 8.3 .i will try 3 new windows 7 3 another computer .and change battery same result.
The Following User Says Thank You to bipugunjan For This Useful Post:
Old 06-02-2015, 00:28   #2 (permalink)
Member: 2398349
Thanks Meter: 62
try with different charging port and a fully charged battery to see if it works!
Old 06-02-2015, 02:03   #3 (permalink)
Crazy Poster
Member: 2131519
Thanks Meter: 8
I'm too.I think EFROM
The Following User Says Thank You to TheDinh596 For This Useful Post:
Old 06-02-2015, 18:59   #4 (permalink)
Member: 88111
I have same same problem.please any solution.
Old 06-02-2015, 23:30   #5 (permalink)
Member: 2398349
Thanks Meter: 62
more likely its baseband IC and u cant do anything abt it
The Following User Says Thank You to sasan500 For This Useful Post:
Old 06-05-2015, 11:15   #6 (permalink)
Member: 2235175
Thanks Meter: 25
i have same problem , iTunes restore error 48
Old 06-15-2015, 16:02   #7 (permalink)
irzhan01's Avatar
Member: 2281582
Thanks Meter: 26
i have same problem tooo
The Following User Says Thank You to irzhan01 For This Useful Post:
Old 06-27-2015, 05:27   #8 (permalink)
Member: 2417185
i have same problem tooo plz help me plz
Old 07-01-2015, 13:43   #9 (permalink)
Member: 1727829
I also have same problem
Old 07-05-2015, 02:29   #10 (permalink)
Member: 1703068
Sonork: purna33
Thanks Meter: 5
i have same error 48 problem plz ,,, help us,,,,,, any masters
Old 07-05-2015, 02:40   #11 (permalink)
Member: 1468994
Thanks Meter: 27
Apple has posted a Knowledge Base article addressing an issue where users receive the error message:
"Error -48 itunes unable to download your update at this time check network connection or settings."
when attempting to restore iPhones in iTunes. The solution, according to Apple, is to delete the iPhone software updates from your system then repeat the restore process, forcing them to be re-downloaded.
Under Mac OS X, these files are located at: ~/Library/iTunes/iPhone Software Updates/
Under Windows Vista, these files are located at: C:/users/[yourusername]/AppData/Roaming/Apple Computer/iTunes/iPhone Software Updates
Under Windows XP, these files are located at: C:/documents and settings/[yourusername]/Application Data/Apple Computer/iTunes/iPhone Software Updates
Apple says that users should remove all files in the iPhone Software Updates directory, then re-attempt the restore from within iTunes.
The Following User Says Thank You to carlosm15 For This Useful Post:
Old 07-05-2015, 19:55   #12 (permalink)
Member: 1815536
Thanks Meter: 4
i did that and that and it's the same.
Old 07-07-2015, 22:06   #13 (permalink)
irzhan01's Avatar
Member: 2281582
Thanks Meter: 26
I have 1 iPad mini again error 48 .. I see on the console my mac iPadupdater log its say.. Basebandupdater : No..the run run and finish with error 48.. So Now i know whats wrong if u get error 48.. Its baseband Corupt .. I will test restore with new Os 8.4 if this still error i think i must Bypass by remove the cellular this iPad ..
Sent from my iPhone using Tapatalk
Old 08-06-2015, 16:09   #14 (permalink)
irzhan01's Avatar
Member: 2281582
Thanks Meter: 26
I think so only one way "bypass" !!
Old 02-22-2016, 16:04   #15 (permalink)
Member: 2512069
Sonork: 100.1612056
Thanks Meter: 13
hello dear i try error 48 replace battery usb cable usb dock check BB ic rebool and rehoot BB ic but same any other solution???????
Page generated in 0.18557 seconds with 8 queries
