GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   iPhone 4 / iPhone 4S (https://forum.gsmhosting.com/vbb/f456/)
-   -   iPhone 4s error -1 Solution (https://forum.gsmhosting.com/vbb/f456/iphone-4s-error-1-solution-1637181/)
gsmexpert2013 04-01-2013 19:09
Hi, i have iphone 4s before restore it was working fine...but now at the end of the restore process...iTunes giving me error -1..and phone is just showing iTunes with Cable sign...after that i have tryed different tricks that i have got from the forum...but i am not able to get rid of the iTunes error -1....if any body have any other solution regarding this issue kindly share here..thanks
i have already tryed following tricks
1- connect with tinyumbrella-6.12.00 and Click on Exit Recovery
2- Remove and change the battery and then restore
3- Replace charging port flex cable and try to restore
cool_male01 04-01-2013 19:13
bro try restore in itunes..not in ipsw..maybe can help u..
UnReality 04-01-2013 19:18
Try to change PC, disable firewall and restore again. Or it can be HW problem too.
ribbentrop 04-01-2013 19:29
Search button works fine, just try it .
mailhassan 04-01-2013 20:56
hey bro,
no perfect solution for any i-device on error -1 at the moment. has to do with a defective baseband chip. but ive tried heating up some ic on the board of an iphone4s that worked for a while. but still entered recovery by itself after a couple of weeks. now back to error -1 again. so u can try urs that way and post results.
cheers
saritha 04-02-2013 09:34
Sorry dear, this is not real solution..............
heartfelt27 04-02-2013 12:12
i have same iphone 4s error -1
i have same iphone 4s it was iphone desabled and when try to restore error -1 appear somtimes in other computer error 14 tried in windows 7 and xp in 3pc
any one have solution
ringtons 04-02-2013 14:05
different cable worked for me
heartfelt27 04-03-2013 09:34
tried 4 or five cable even one of them have only 20 cm long
tried 4 or five cable even one of them have only 20 cm long but no success i wounder if could to flash with custom firmware i will make a searche!
ikloveto 04-03-2013 09:49
-1 hardware problem baseband cant write thats why you got -1 error
heartfelt27 04-03-2013 10:09
thanks for answer then am i right to say flash with custom firmware to prevent or bypass base band when flash???
Malik_GSM 04-03-2013 10:24
try to do this but i think this is not work all...........bcz BB is very importent.....when u flash it...........
vishalbarara 04-03-2013 14:18
download fresh copy of firmware and restore again work for me 3 times
enterprises 04-03-2013 14:34
no solution stilll
i also try iphone 4
when phone start restoring after a while it give -1 error
customer says i was updating my phone....
Killalores 04-03-2013 22:40
if anyone finds a solution to get the phone to boot even without a baseband i dont care i just wanna turn the damn thing on lol please pm me or post here
Page generated in 0.17287 seconds with 6 queries
