iPhone 4S error 3 - baseband? iPhone 4s stuck in recovery mode, iTunes giving error 3 at the final stages of restore. I has had previous water damage, but i fixed it, it was working fine, then was "searching" constantly so i restored and now im in recovery loop ....... [03:51:56.0676] bbupdater: Creating transport, attempts remaining 3...bbupdater: OK [03:51:56.0676] bbupdater: Baseband VendorID [0x5C6] ProductID [0x9008] [03:51:56.0676] bbupdater: Modem not booting [03:51:56.0676] bbupdater: Modem not booting, attempts 0 [03:51:56.0676] bbupdater: END(kBBUReturnIOError): Preparing Initial stage [03:51:56.0676] bbupdater: END(kBBUReturnIOError): Perform stage at second [03:51:56.0676] send_bbupdate_status: sending baseband update status to host [03:51:56.0676] update_baseband: bbupdater error: The operation couldn\U2019t be completed. (BBUpdater error 3 - Modem returned to download mode) [03:51:56.0676] 0: RamrodErrorDomain/3ec: update_baseband: failed to perform next stage [03:51:56.0676] 1: BBUpdater/3: Modem returned to download mode [03:51:56.0676] unable to convert ramrod error 1004 [03:51:56.0676] [03:51:56.0676] ==== end of device restore output ==== [03:51:56.0806] AMRAuthInstallDeletePersonalizedBundle [03:51:56.0929] Restore completed, status:3 [03:51:56.0929] Failure Description: [03:51:56.0929] Depth:0 Error:AMRestorePerformRestoreModeRestoreWithError failed with error: -1 [03:51:56.0929] Depth:1 Error:The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg) [03:51:56.0929] Depth:2 Error:The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - failed to update device firmware) [03:51:56.0929] Depth:3 Error:The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - ramrod firmware update failed) [03:51:56.0929] Depth:4 Error:The operation couldn’t be completed. (RamrodErrorDomain error 1004 - update_baseband: failed to perform next stage) [03:51:56.0929] Depth:5 Error:The operation couldn’t be completed. (BBUpdater error 3 - Modem returned to download mode) I opened it up and there was no visible corrosion, cleaned it all with 100% isopropyl and toothbrush to ensure no corrosion (should I reclean certain areas?) and still error 3 I researched and its probably a baseband problem, all i have is a solder and an oven, I don't know how to do any rehotting or reflowing or anything but if its necessary i will learn? Can somebody please help me out, its urgent Thanks so much |
