iphone 4s error 4013...solution please the owner field to update ios7 because error in itunes restoring ( error 4013) i try to restore in version 6.1.3, 7.0.2 and 7.0.3 but still error 4013. i use original usb cable. imei: 013057009768982 help please............ |
bro try to flash the phone without the casing,, remove the board from the casing and connect battery and use good cable,, i had a lot of issue like that before. this is a 100% working,, hope it will help to sort your problem.. |
i need more idea and suggestion please!!! |
bro you're from phil.. just try that solution bro.. i just fixed one same issue like yours.. |
still error................ |
remove sensor flat and restor 100% worked |
wifi module rehot or changed I tested %%100 |
[QUOTE=shadycenter777;9972212]remove sensor flat and restor 100% What do you mean sensor flat and what value of the resistor and where exact location for the part? |
hello I have an iphone 4s after contact with water and was washed with ultrasound now hangs on the apple and error 4013 what do I do? |
hi i have the same problem. i have try to disconnect flex cable > nothing i have remove r95rf but no working.... i just clean the dock and dfu + ireb and miracle the phone restore well. the wifi is working too. regards |
delete line of apple in host files |
anyways, delete line of apple in host file on apple macbook How to do? sag |
battery problem, because my iPhone kept on showing the apple logo continously with the Battery logo seconds later on red all the time.. I go and buy a new battery. On a numerous of accassions i research near enough evrything on the error code (4013) and near enough all the people who fixed this problem had a new battery installed. |
just change R108_RF and R106_RF and done ... |
