Old 11-01-2013, 05:22   #1 (permalink)
markrhoden's Avatar
Member: 981198
Sonork: 100.1602386
Thanks Meter: 118
iphone 4s error 4013...solution please
the owner field to update ios7 because error in itunes restoring ( error 4013)
i try to restore in version 6.1.3, 7.0.2 and 7.0.3 but still error 4013.
i use original usb cable.
imei: 013057009768982
help please............
Old 11-01-2013, 05:35   #2 (permalink)
Member: 855662
Sonork: yorx
Thanks Meter: 5
bro try to flash the phone without the casing,, remove the board from the casing and connect battery and use good cable,, i had a lot of issue like that before. this is a 100% working,, hope it will help to sort your problem..
The Following 2 Users Say Thank You to chuchay22 For This Useful Post:
Old 11-01-2013, 05:37   #3 (permalink)
markrhoden's Avatar
Member: 981198
Sonork: 100.1602386
Thanks Meter: 118
i need more idea and suggestion please!!!
Old 11-01-2013, 07:39   #4 (permalink)
Member: 855662
Sonork: yorx
Thanks Meter: 5
bro you're from phil.. just try that solution bro.. i just fixed one same issue like yours..
The Following User Says Thank You to chuchay22 For This Useful Post:
Old 11-01-2013, 11:22   #5 (permalink)
markrhoden's Avatar
Member: 981198
Sonork: 100.1602386
Thanks Meter: 118
still error................
Old 12-23-2013, 21:01   #6 (permalink)
Member: 509938
remove sensor flat and restor 100% worked
Old 12-26-2013, 17:16   #7 (permalink)
Member: 242163
Thanks Meter: 15
wifi module rehot or changed I tested %%100
Old 01-06-2014, 17:16   #8 (permalink)
Member: 4691
Thanks Meter: 41
[QUOTE=shadycenter777;9972212]remove sensor flat and restor 100%
What do you mean sensor flat and what value of the resistor and where exact location for the part?
Old 02-01-2014, 14:55   #9 (permalink)
Member: 2077779
hello I have an iphone 4s after contact with water and was washed with ultrasound now hangs on the apple and error 4013 what do I do?
Old 02-13-2014, 01:23   #10 (permalink)
Member: 119941
Thanks Meter: 3
hi
i have the same problem.
i have try to disconnect flex cable > nothing
i have remove r95rf but no working....
i just clean the dock and dfu + ireb and miracle the phone restore well.
the wifi is working too.
regards
The Following User Says Thank You to cimeurop34 For This Useful Post:
Old 02-20-2014, 21:24   #11 (permalink)
Member: 1845605
delete line of apple in host files
Old 02-22-2014, 17:26   #12 (permalink)
Member: 2074110
Sonork: 92458589.7230895
Thanks Meter: 9
anyways, delete line of apple in host file on apple macbook How to do?
sag
Old 02-23-2014, 11:52   #13 (permalink)
Member: 1876831
Sonork: 100.1626615
Thanks Meter: 4,294,967,295
battery problem, because my iPhone kept on showing the apple logo continously with the Battery logo seconds later on red all the time.. I go and buy a new battery. On a numerous of accassions i research near enough evrything on the error code (4013) and near enough all the people who fixed this problem had a new battery installed.
Old 02-26-2014, 09:20   #14 (permalink)
Member: 1876831
Sonork: 100.1626615
iTunes Error Collection With Solutions [DISCUSS]
Old 06-26-2014, 15:26   #15 (permalink)
Member: 1988296
Sonork: 100.1656132
just change R108_RF and R106_RF and done ...
Page generated in 0.32382 seconds with 7 queries
