11-18-2014, 19:10 | #4 (permalink) |
Freak Poster Join Date: Oct 2014 Location: Gsm crackZzz Age: 33
Member: 2270367 Status: Offline Sonork: 100.1668469 Thanks Meter: 192 | hw problem Hi if you use last itunes and you have tested usb hosts etc the problem is at proximity sensor flex. Remove the sensor and try agin without connected then replace it. |
11-19-2014, 11:00 | #6 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2288457 Status: Offline Sonork: [email protected] Thanks Meter: 1 | I also am having problems with iphone 4s, legal scrabble remove r95 and wifi ic failed |
11-23-2014, 21:58 | #8 (permalink) |
Freak Poster Join Date: Aug 2011
Member: 1641104 Status: Offline Thanks Meter: 22 | I had the same problem for 3 DAYS!!!! My 4S had no water damage, Never Dropped and was working PERFECTLY before tying to update to ios 8.1. And it gave me error 4013 while updating. Here is what I did after a few days of playing around with it. I finally fixed it.. I could not believe it. From reading people say remove the prox flex cable... Here is what I did. I used a clean laptop. No iphone jailbreaking programs. tiny umbrella ect... I removed both cameras, power flex, vol flex. And in Itunes I used IOS 8.1 NOT IOS 8.1.1 I put the 4S in recovery (press home button and plug in to itunes) And pressed Shift on my keyboard and pressed UPDATE on itunes. Searched for my IPSW 8.1 And it itunes updated my 4S I hope this post helps someone!!! |
11-25-2014, 10:55 | #9 (permalink) |
Junior Member Join Date: Sep 2012 Location: Dubai United Arab Emirate
Member: 1813694 Status: Offline Sonork: 100.1621242 Thanks Meter: 3 | Hi my friends I just found the solution don't do anything stupid Just change the Battery and try to restore it. Its work for me for you have good luck. Bye |
