Old 05-24-2016, 11:59   #1 (permalink)
Member: 2029498
Thanks Meter: 9
Iphone 4s Itunes reset Error
Hi i have a iphone 4s when i do reset with itunes software show this error:
"Unable to recover iphone unknown error (-1)"
Itunes is update at the last version, firewall and antivirus is off.
i have change also the battery but i dont solve the problem.
Solution?
Old 05-24-2016, 12:43   #2 (permalink)
Benntek's Avatar
Member: 2461747
Thanks Meter: 39
Download 3utool and update your phone with it
Old 05-24-2016, 15:23   #3 (permalink)
Member: 2029498
Thanks Meter: 9
also with 3utool ERROR: Unable to restore devices (-1)
Old 05-25-2016, 01:33   #4 (permalink)
gunit1's Avatar
Member: 2041210
Thanks Meter: 489
3utool download last version firmware and flash it will working
Old 05-25-2016, 01:59   #5 (permalink)
Member: 2556065
Sonork: 100.1673069
Thanks Meter: 3
try to another computer......
Old 05-25-2016, 04:25   #6 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,092
Or use search!!! It was posted many times!
Old 05-25-2016, 05:14   #7 (permalink)
Member: 2264691
Thanks Meter: 12
hi brother if you already tried another computer
and also via 3utools and same error if im not mistaken this is a baseband ic
try this one dis assemble the unit then mild reheat the baseband ic via soldering tip with lead...then try to restore again with no lcd attach via 3utools..hope this can help
Old 05-25-2016, 09:35   #8 (permalink)
Member: 2029498
Thanks Meter: 9
you do not believe that I already did before writing here ?
Old 05-25-2016, 09:38   #9 (permalink)
Member: 2029498
Thanks Meter: 9
i have try to 3 different pc.
the 3utools is update at the last version at the 99% show this error.
Old 05-25-2016, 09:51   #10 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,092
And what? Don't you make conclusion from that info?
it's a hardware problem
Old 05-25-2016, 10:04   #11 (permalink)
Member: 2029498
Thanks Meter: 9
I think it is a forum where we help each other to solve problems , I'm sorry if it bothers you having to read and respond to this post .
but now I try to heat the component and reflash the firmware. thanks
Old 05-25-2016, 10:32   #12 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,092
Yeah... next time start using forum with reading the rules
>Forum Rules< Read Before You Use This Forum
Always Use Search Button And Check STICKY THREADS Before You Post or Open New Thread (If You Wanna be Professional Start Reading and Searching ).
Page generated in 0.38262 seconds with 7 queries
