Old 03-08-2014, 07:14   #1 (permalink)
Member: 1282074
iphone 4s network problem
hi everybody,
i really need help with my iphone 4s the problem is that when i do manual searching i can found networks but when i select one of them it do nothing just keep searching then no service, and also when i do automatic network selection it keep searching then no service.
i do new firmware for my iphone "ios 7.0.6" ,time and date are ok.
please help.
Old 03-08-2014, 07:26   #2 (permalink)
Member: 1584831
Thanks Meter: 43
try to call 112 , if the calls connect then the network section is ok, try some thing other...
The Following User Says Thank You to ashish.srk2 For This Useful Post:
Old 03-08-2014, 07:50   #3 (permalink)
Member: 126771
Thanks Meter: 20
ihave iphone 4s same problem
Old 03-08-2014, 08:11   #4 (permalink)
Member: 1282074
i try that the call not connect
Old 03-09-2014, 22:54   #5 (permalink)
Member: 1424925
Sonork: 100.1614407 TOPUNLOCKING
Thanks Meter: 72
my iPhone 4s 7.0.6 not activate Error: invalid sim, no sim, searching
plzz help me.....
Old 03-11-2014, 07:28   #6 (permalink)
Member: 2145002
Hello,
Please make sure your phone is not locked to any specific carrier, you will get these problems if you are using a sim card that is not on the same carrier network as the phone is locked to. Also see if roaming is turned on, or if your sim allows roaming
Also make sure you have a working sim try it in another phone?
maybe try resetting network connections
After that if phone and sim are compatible there was a trick that i came across a little while ago, though cant remember fully, and cant find the info again, but it went something like this.
Turn phone off.
Start iTunes on pc.
with phone off hold home button and plug into pc.
keep holding home button until iTunes recognises it.
see if it working now?
after that if that didn't work while plugged in do a hard reset, but i don't think you need to do that.
Maybe some one can help on this fix for exact steps thanks ?
good luck
Page generated in 0.24753 seconds with 7 queries
