01-23-2013, 05:48 | #2 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Inside the World
Member: 1835240 Status: Offline Sonork: 100.1624260 Thanks Meter: 26 | [IMG][http://img841.imageshack.us/img841/1...44831f520.jpg][IMG] Procedure: Jailbreak Model: Iphone 2G Firmware: 3.1.3 Tools: - Redsnow 0.9.4 - IPhone 3.1.2 .ipsw file Method: 1) Connect IPhone to computer 2) Run Redsnow 0.9,4 3) Download 3.1.2 ipsw file listed in links section. If you already have it skip this step 4) Select Browse. Point to the 3.1.2 ipsw file you have downloaded. It is suggested you extract the file to the desktop for ease of access 5) You will arrive at a menu asking you to select your options. 6) Check Cydia 7) Leave all other boxes unchecked - "Already pwned" option - For when you are already jailbroken and you are customizing - "Unlock" option - If an unlock option displays. It is recommended you select it. You will need two additional files (3.9 Bootloader and 4.6 Bootloader) Search to obtain. You would then navigate to these two files in their respective boxes. Then select continue. Recommended for 2G. As Bootneuter application is used for unlock. 8) Ensure your device is connected to your computer and that the power is off. 9) Put your device into recovery as per on screen instruction. Hold power and Home keys until continuation commences 10) After a short pause. Relase Power but continue to hold the Home key. 11) Once complete device will automatically restart Additional notes: - If you are having trouble renaming the ipsw file. If it is in zip or rar format. Ensure "hide known file extensions" option is unchecked in folder options. - Change the name to .ipsw extension from .rar/.zip Unlocking: The following unlock process is recommended for 2G users. If you have previously unlocked your 2G upgrading to 3.1.3 will disable your unlock. 1) Go to cydia 2) Search>BootNeuter Run device as per following preferences: Version: 4.6 Neuter: On FakeBlank: Off Unlock: On thankz... ORIGINAL LINK.. http://anonymous00.hubpages.com/hub/...Unlock-Redsnow |
