Old 03-30-2016, 08:31   #1 (permalink)
Muhammadsaqib11's Avatar
Member: 1602407
Sonork: 100.1648061
Thanks Meter: 341
iphone 4s restoring error 3194 help please
hosts file created but same.........
any other solution?
Old 03-30-2016, 08:43   #2 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,064
What is the firmware version you tried to flash?
Old 03-30-2016, 08:51   #3 (permalink)
Member: 2087409
Thanks Meter: 30
allways use latest virsion to flash.
bcoz apple server block sing of old firmware.
one more way start tiny umbrela on side and update whith itune latest virsion.
i hope you understand...thanks..
Old 03-30-2016, 09:23   #4 (permalink)
aircraft's Avatar
Member: 1869762
Thanks Meter: 52
If case use 9.3 download new build 237 old 233 is not signed. This is solution about 3194
Sent from my iPhone using Tapatalk
The Following User Says Thank You to aircraft For This Useful Post:
Old 03-30-2016, 10:41   #5 (permalink)
Member: 1602407
Sonork: 100.1648061
Thanks Meter: 341
with 9.3 ios 13e237 (3utools) pro flash
Below devices support to professional flash:
iPod Touch2, iPod Touch3, iPod Touch4, iPod Touch5, iPod Touch6
iPad1,iPad2,iPad3,iPad4,iPad Air,iPad Air2,iPad mini/2/3/4,iPad Pro
iPhone3G,iPhone3GS,iPhone4,iPhone4s,iPhone5,iPhone5c,iPhone5s,iPhone6,iPhone6 Plus
Steps to enter DFU mode:
1. Keep device in normal mode or recovery mode, plug USB cable (please don't use USB extension cable)
2. Hold HOME button, then hold power button until screen is blank
3. Release the POWER button after about 4 seconds, but keep holding the HOME button for about 10 seconds
14:11:26   Friendly reminder:
14:11:26   Please make sure device turned off 'Find My iPhone'
14:11:26   The device will can not activated without Apple ID after flash, in case device turned on 'Find My iPhone'
14:11:26   Method to check: Settings -> iCloud -> Find My iPhone
14:11:26   Please connect USB cable to apple mobile device, make sure you are in DFU mode14:12:29   Retrieving information from apple mobile device14:12:29   SRTG:[iBoot-838.3]
14:12:29   Device ECID: 00000210E010834C
14:12:29   Product Type: iPhone4,1
14:12:29   Product Name: iPhone4s
14:12:29   MAIN CPU ID : 8940
14:12:29   Verifying firmware file14:12:48   MD5 value of firmware : 074670FF4FD2527678561E0BBE94A3DD
14:12:48   Filename of firmware : iPhone4,1_9.3_13E237_Restore.ipsw
14:12:48   MD5 value is different from official firmware, maybe firmware has damaged
14:12:48   Unzipping firmware file14:14:13   Apple server no longer supports the flash of this firmware version
14:14:13   Failed to flash
14:14:13   If the device doesn't exit current mode
14:14:13   Please hold the HOME and POWER buttons for about 10 seconds
14:14:13   Flash and jailbreak of apple device, please visit official website of 3uTools http://www.3u.com
14:14:13   Elapsed Time: 00:01:44
with ios 9.3 13e233 (3utools) pro flash
14:15:39   Friendly reminder:
14:15:39   Please make sure device turned off 'Find My iPhone'
14:15:39   The device will can not activated without Apple ID after flash, in case device turned on 'Find My iPhone'
14:15:39   Method to check: Settings -> iCloud -> Find My iPhone
14:15:39   Please connect USB cable to apple mobile device, make sure you are in DFU mode14:16:18   Retrieving information from apple mobile device14:16:18   SRTG:[iBoot-838.3]
14:16:18   Device ECID: 00000210E010834C
14:16:18   Product Type: iPhone4,1
14:16:18   Product Name: iPhone4s
14:16:18   MAIN CPU ID : 8940
14:16:18   Verifying firmware file14:16:27   MD5 value of firmware : 885599C9C52DB8CA2BE5F5F7F59CFFDA
14:16:27   Filename of firmware : iPhone4,1_9.3_13E233_Restore.ipsw
14:16:27   MD5 value is different from official firmware, maybe firmware has damaged
14:16:27   Unzipping firmware file14:17:44   Apple server no longer supports the flash of this firmware version
14:17:44   Failed to flash
14:17:46   If the device doesn't exit current mode
14:17:46   Please hold the HOME and POWER buttons for about 10 seconds
14:17:46   Flash and jailbreak of apple device, please visit official website of 3uTools http://www.3u.com
14:17:47   Elapsed Time: 00:01:29
with easy flash
and itunes still is giving error 3194 same as before
Old 03-30-2016, 11:28   #6 (permalink)
Member: 1602407
Sonork: 100.1648061
Thanks Meter: 341
also tried with 9.2.1
still same
3194 error
any expert here...........
help please
Old 03-30-2016, 11:31   #7 (permalink)
aircraft's Avatar
Member: 1869762
Thanks Meter: 52
No 9.2.1 use build 9.3
Or put device in dfu and get ipsw via iTunes and make new hosts
Old 03-30-2016, 12:13   #8 (permalink)
Member: 1602407
Sonork: 100.1648061
Thanks Meter: 341
hosts created, i tried with 9.3 both 13e233, 13e237
i think md5 not machting.......therefore come this error 3194
Old 03-30-2016, 14:15   #9 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,064
Fffffff!!! use 9.2.1 version for flashing and do not hesitate use search function on forum!
The Following User Says Thank You to ribbentrop For This Useful Post:
Old 03-30-2016, 17:01   #10 (permalink)
Member: 1602407
Sonork: 100.1648061
Thanks Meter: 341
only change pc.......all process going fine but at the end when make a restart hang there and error 48 comes.
not what is solution for it.?
search a lot on google and listen from mostly people that it is h/w.
Old 03-30-2016, 18:09   #11 (permalink)
Member: 2087409
Thanks Meter: 30
i m sorry budluck bro..
i think hardware...
this codition same issue on iphone 5c 5 month past
iphone is working fine but after updATE SAME ERROR AND DEVICE HANG ON LOGO AND RESTART......
The Following User Says Thank You to saddamh517 For This Useful Post:
Old 03-30-2016, 20:36   #12 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,064
Seems like something wrong with HW in your phone, because I just downloaded and flashed 4s with iPhone4,1_9.3_13E237_Restore.ipsw. Apple signs this firmware ATM.
And once more, 3uTools refuses to flash new 9.3 version, I've used iTunes.
Old 03-31-2016, 08:43   #13 (permalink)
Member: 1602407
Sonork: 100.1648061
Thanks Meter: 341
i think hardware...
ahhh.......badluck
thanks for inform about 3utool bro.
i tried with itunes too but same.
anyway....thanks to all friends for participate and help too.
Old 04-01-2016, 07:55   #14 (permalink)
Member: 2494453
Thanks Meter: 190
3uTools (V1.07)Easy Flash can flash new9.3(13E237), and 3uTools (V1.08) pro flash can normally support new 9.3(13E237).
So you're suggested to use Easy flash when you need to flash the firmware whose signing hasn't been stopped by Apple.
If you have any questions and feedback about 3uTools, please send them to me or here https://www.facebook.com/3utool/?fref=ts. So you can get a quick solution. Thank you sir.
Old 04-01-2016, 07:59   #15 (permalink)
Member: 2494453
Thanks Meter: 190
with easy flash
Hi sir. The version below v1.07 can't flash new 9.3 using Pro Flash. 3uTools V1.08 can support it using Pro Flash. Did you flash new 9.3(13E237) using Easy Flash?
Page generated in 0.44796 seconds with 7 queries
