07-04-2014, 20:15 | #1 (permalink) |
Insane Poster Join Date: Feb 2010 Location: Sohag, Egypt
Member: 1234128 Status: Offline Thanks Meter: 12 | iPhone 4S Unlocked but No Service Here are the info: IMEI : 013046009796788 Unlock code : IMEI: 013046009796788 Serial: C39H328QDTDT MEID: Model: IPHONE 4S WHITE 64GB GSM-SPA ICCID: 8920013006090611040 Activated: true Factory Unlocked: true iOS: 7.1.2 First Activation Date: 26/03/12 Last Activation Date: 03/07/14 Warranty: Out Of Warranty (No Coverage) Warranty Started: Warranty Ends: Warranty Remaining Days: 0 Purchase Date: 25/03/12 Purchase Country: Mexico Bluetooth Mac Address: 44D88410F11B WiFi Mac Address: 44D88410F11A Initial Activation Policy Description: Mexico America Movil Unlocked Policy Applied Activation Policy Description: Mexico America Movil Unlocked Policy NextTetherPolicyDetails: Mexico America Movil Unlocked Policy Lock Status: Unlocked Find my iPhone: OFF Is it 100% unlocked ? If so, why there is no service ? What are the aspects of a locked iPhone 4s on iOS 7.1.2 ? I mean, back in the days of iOS 5 and 6 when my iPhone 4 was locked, I couldn't activate the phone without the original Sim so I used hacktivation then SAM but with this iPhone 4s it activates fine with any other SIM. Also when I check Settings, About, it says Network: Not Available but it identifies all Egyptian carriers when I use different SIMs in it like Mobinil 16.0 or Vodafone 16.0 while in the past my locked iPhone 4 only showed something like: Carrier Lab 11.0. Also in Carrier Network Selection when I disable Automatic detection it shows all our 3 network carriers and I can select any of them but still No Service. Do all these things suggest a locked or an unlocked iPhone ? Thanks |
The Following User Says Thank You to r9800pro For This Useful Post: |
07-05-2014, 15:06 | #4 (permalink) |
Member: 1234128 Status: Offline Thanks Meter: 12 | Tried all that and nothing works. Dialing 112 for Emergency calling doesn't do anything at all, it is stuck at "calling" screen. Calling any other number just shows "calling" for 15-25 seconds then says "call failed" |
07-18-2014, 10:11 | #6 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1913935 Status: Offline Thanks Meter: 1 | update to the latest Ios version and all will work perfect. its a problem since the Ios 7 was released. had many phones unlocked with the same problem. just update it with the latest firmware. good luck |
07-25-2014, 20:41 | #9 (permalink) |
Junior Member Join Date: Apr 2014 Location: INDIA,HongKong
Member: 2177978 Status: Offline Sonork: 100.1614120 Thanks Meter: 6 | Try to reset network settings if not works then try to restore phone with itunes if still not solved then check phone hardware Br Naksh |
07-27-2014, 20:34 | #10 (permalink) |
Freak Poster Join Date: Aug 2009
Member: 1097251 Status: Offline Sonork: monk Thanks Meter: 13 | two things first do normal update to latest version if doesnt work..open phone and check antena first..could just be detattched from main board. One of the two should work. |
08-03-2014, 10:30 | #11 (permalink) | |
Super Moderator Join Date: Dec 1999 Location: In EveryOne's Heart
Member: 824 Status: Offline Thanks Meter: 25,142 | Quote:
is your entina wire attach? Is your set water damaged? tell me then i can help you. | |
