07-07-2015, 21:16 | #1 (permalink) |
Freak Poster Join Date: Sep 2011
Member: 1663240 Status: Offline Sonork: 505020 Thanks Meter: 12 | What is iTunes error 48 while restoring iPhone 4s? |
08-21-2015, 09:05 | #3 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2434367 Status: Offline Thanks Meter: 0 | I 've also done what exactly you did. my phone was also working very nicely before but after resetting to factory setting to make by jailbroken iphone to make it clean it stuck. After restoring it though itunes it gives error 48. Mac sopport service in my country says it is board problem and cannot be fix. it wouldn't be like this if i wouldn't have factory reset to my jailbroken iphone 4s. Seems very much like software issue , hard to believe isn't it |
08-21-2015, 09:44 | #4 (permalink) |
Freak Poster Join Date: Apr 2011 Location: ndola,zambia
Member: 1564630 Status: Offline Sonork: the blackchinese Thanks Meter: 18 | From what you have said,the iphone was jailbroken.You will not succeed updating a jailbroken iphone using itunes server.So try this : 1. download the current firmware of your device 2. run itunes and connect iphone in recovery mode 3. hold shift on the keypboard and press restore 4.select the firmware from the folder you had put it. 5.the process will begin and if you got the correct firmware ,your iphone 4s will be restored. Note.Apple has made it clear that support is not available for jailbroken iphones. you will only succeed if 1.iphone 4s has previuos firmware of what they are signing 2.if warranty is not void due to infringement 3. If the iphone is in original form apple made it .SOFTWARE and HARDWARE. Jailbreaking is an infringement.Pity they just can"t tell you the truth. |
The Following User Says Thank You to NICK T For This Useful Post: |
