Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 5 / 5S / 5C
LinkBack Thread Tools
Old 09-25-2012, 03:08
Member: 1283129
Thanks Meter: 17
iPhone 5 iOS 6.0 FACTORY UNLOCKED HOW TO EDIT APN SETTINGS
I have a factory unlocked Apple iPhone 5 on iOS6. I am trying to manually configure the APN settings so picture messaging and internet will work but there is no place to do it (on 5.1.1 it was settings/general/network). Any help appreciated.
Old 09-25-2012, 04:46
Member: 183390
Thanks Meter: 56
Just look for a wifi man . then goto to www. unlockit.co.nz make your own apn done happy browsing
The Following User Says Thank You to Qmad3 For This Useful Post:
Old 09-25-2012, 14:29
Member: 1283129
Thanks Meter: 17
That works fine for web browsing but still need to enter the APN settings for MMS to work. Any suggestions.
Old 09-25-2012, 15:57
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 49,078
on my iphone ios6 it's
settings->general->cellular->cellular data->
Faisal_Computer
Old 09-25-2012, 17:13
Member: 534374
Thanks Meter: 4
Question
Same problem...i have iphone 4S iOS 6 unlocked...but when i use H20 but "Cellular Data" option disappear...i'm trying t-mobile sim card "cellular data" option appears....
any idea??...maybe i need install "tetherme"
BR,
Tech
Old 09-27-2012, 12:15
Member: 342027
Thanks Meter: 73
Connect wifi , then go to www. unlockit.co.nz , select make apn will apears the network , select network that you use , install , restart phone.
The Following User Says Thank You to cela_relly For This Useful Post:
Old 09-27-2012, 12:36
Crazy Poster
Member: 1431
Advertisement not allowed in this sec
Old 09-27-2012, 12:55
Member: 1762185
Thanks Meter: 48
Maybe he has no wifi access.
Do it with itunes.
iPhone, iPhone 3G, iPhone 3GS, iTunes 9 for Windows, iTunes 9 for Mac, iPad Wi-Fi + 3G
Carrier settings updates are small files (about 10k) that are downloaded from iTunes to be installed on your iPhone or iPad Wi-Fi + 3G. The carrier settings can include updates to the default APN (how the device accesses the carrier's cellular data network). The carrier settings for iPhone also include special dialing codes at Settings > Phone > [Carrier] Services, default settings for Stocks, Maps, Weather, and other items. When you insert a new SIM or micro-SIM into an iPhone or iPad Wi-Fi + 3G, you must connect the device to a computer running iTunes to download the latest carrier settings. You should also install the latest carrier settings updates for your device as soon as they are available.
To check if a carrier settings update is available for your iPhone or iPad Wi-Fi + 3G:
  1. Make sure there is an appropriate SIM or micro-SIM installed in your iPhone or iPad, that you have a working Internet connection on your computer, and that iTunes 9.1 or later installed on your computer.
  2. Connect the device to your computer and open iTunes.
  3. If a carrier setting update is available iTunes displays a prompt:
  4. Click "Update Settings" to load the confirmation dialog.
  5. Click OK to dismiss the confirmation dialog.
  6. Restart your device:
    1. Hold the power button until "slide to power off" appears.
    2. Slide to power off your device.
    3. When it is off, press the power button to turn it back on.
Additional Information
The carrier update files are stored in your computer in the following locations.
see here
Old 09-27-2012, 18:41
Member: 534374
Thanks Meter: 4
Thanks buddy...internet connection again...works fine!!!
BR,
Tech
Powered by Searchlight © 2014 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.41365 seconds with 7 queries
