11-15-2009, 12:10 | #1 (permalink) |
Junior Member Join Date: Oct 2005
Member: 188329 Status: Offline Thanks Meter: 8 | iphone back light solution |
The Following 6 Users Say Thank You to mertt For This Useful Post: |
11-19-2009, 10:52 | #6 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1163420 Status: Offline Thanks Meter: 10 | mertt send me an email today, with this image : He seems to say, that we must change those to make the backlight work properly. |
The Following 10 Users Say Thank You to Dexter55 For This Useful Post: |
11-23-2009, 20:31 | #7 (permalink) |
Junior Member Join Date: Sep 2005 Age: 62
Member: 177515 Status: Offline Thanks Meter: 0 | Greetings everybody. I ve iPhone 3G 16GB, no backlight as soem other of us :-) I guess I did a shortcut while I was connecting the connector nr1 (i pressed it too much to left). (Or the flexcable went off as I bend it too much). I did not changed my LCD yet but I have ordered it already. My motherboard looks different than one on the picture above. Any of You repaired that backlight yet? By changing the parts in red circle? Anyone has an idea witch of the pins in the connector nr 1 gives the current to a backlight? I wish to be sure there is NO juice there before I desolder anything on the MB. Be well folks! Cuba |
11-24-2009, 00:37 | #8 (permalink) |
Freak Poster Join Date: Aug 2008 Location: cpr-orlando.com
Member: 843747 Status: Offline Thanks Meter: 40 | Clean the connection on the board and lcd flex with a stiff toothbrush and alcohol not the cheap stuff you have in you bathroom, go to CVS or Walgreens or a Walmart get the 91%+ alcohol not the 70% stuff (water is what got you in this mess) clean the water damaged locations and use a heat gun ot a HOT hair dryer to dry things up if it still dosent work then the lcd has been shorted out REPLACE then lcd.. |
12-01-2009, 12:27 | #11 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: Monrovia
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | Quote:
Br. amanvir | |
01-05-2010, 03:39 | #15 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 895524 Status: Offline Thanks Meter: 33 | really depends the situation your are in GUYS . But i would always suggest to inspect both the connectors for you LCD and the main board LCD connector. Clean, or clean and resolder the joins if there any corrosion, if still dont work change LCD, if it doesnt work still wash the board and use ultra sound cleaning device/washer, if it still dont work try reheat or try changing new coils on the board . to take coil out you will need a plastic weller(desolder), heat chip about 450degree and should come off. then resolder it. Word of advice stay away from the black sealer bits, it might heat up and bust your board >.< Also another general rule when REPLACING IPHONE LCD SWITCH OFF THE DARN PHONE |
The Following 3 Users Say Thank You to kawaichang For This Useful Post: |
iphone 3g screen back light | lxa786 | iPhone, iPad, iPod Hardware Repair | 17 | 03-09-2011 17:25 |
Iphone no light solution | mamun_iqbal2000 | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 01-18-2010 16:31 |
back light problem in Iphone | askaralikp | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 11-15-2009 12:07 |
1110 back light any solutions? | abeesh | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 06-02-2006 15:47 |
any solution about back light for ot511 | freemobil | BF, BG, TH, BHx Series | 1 | 01-30-2005 10:15 |
