07-06-2012, 16:08 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: DUBAI Age: 33
Member: 1189306 Status: Offline Sonork: 100.1589231 Thanks Meter: 273 | iphone backup password??? ( The password u enter to unlock your iphone backup was incorrect. plz try again) and i know the password... Any solution ?????coz *******r says i have importent data ???? bro |
07-06-2012, 16:17 | #2 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 961957 Status: Offline Sonork: Jabber: [email protected] Thanks Meter: 641 | Use the Apple ID password (iTunes account) or bruteforce with this http://www.golubev.com/igprs/ |
07-06-2012, 16:43 | #5 (permalink) | |
Member: 961957 Status: Offline Sonork: Jabber: [email protected] Thanks Meter: 641 | Quote:
01-11-2013, 04:44 | #7 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1866608 Status: Offline Thanks Meter: 1 | I found a solution to your problem, as I was having the same problem for about a week. If you are using Mac, then go to Applications -> utilities -> keychain Access. Once the program opened, type iPhone. You`ll find the device and login in this list. Click on one of them, the new window will open. Click on show password, enter your Mac administrator password, then you can see your iPhone encryption password. Hope it helps you. If the above can’t help you, I also found a solution using an external program to decrypt backup password. You can try to use the application below just download the trial version and check if the password will be detected and will be recovered. It is “iPhone Backup Password Unlocker”. The Q&A on how to unlock iPhone backup password will also help you much! Please let me know if this helps. Thanks |
The Following User Says Thank You to honeyerb For This Useful Post: |
10-11-2014, 08:40 | #9 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2252469 Status: Offline Thanks Meter: 0 | I think if you did not change the iTunes backup password during the time, then the password would not change even though your iPhone has been upgraded. The iOS upgrading has nothing to do with the iTunes backup password, so it remains the same as long as you do not change it. So, one possibility is that you memorize the wrong password. Then, the only thing you can do is to use a password recovery tool to find out the password. It is said that Jihosoft iTunes Backup Unlocker is not bad, maybe you can give it a try to see if it suits your need. Good luck! |
12-03-2018, 04:03 | #10 (permalink) |
Junior Member Join Date: Aug 2018 Location: new york
Member: 2861348 Status: Offline Thanks Meter: 4 | If you have forgotten the password for iTunes encrypted backup, you can fix this by following these steps: On your iOS device, go to Settings > General > Reset. Tap Reset all settings and enter your iOS password. Follow the steps to reset your settings. This will not affect your user data or password but will reset settings such as display brightness, home screen layout, and wallpaper. It will also delete your encrypted backup password. Connect your device to iTunes again and create a new encrypted backup. You will not be able to use the previous encrypted backup, but you can use iTunes to back up your current data and set a new backup password. If your device uses iOS 10 or earlier, you won't be able to reset your password. In this case, try the following: If someone else has set up your device, ask for their password. If this method is not feasible, you can also try using an older iTunes backup. of course, you can try to use another method like using third-party tool to fix your iPhone backup password issue. |
Wanted 6130 4.02 full backup Pls Read | Charly | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-06-2001 05:12 |
Password for............ | Miko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 04-24-2000 19:08 |
Do you know the password | kf89 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-02-1999 19:55 |
I need passwords for new bontiek sites programs | Zahooo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 09-10-1999 22:42 |
