04-20-2013, 07:19 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: india/delhi
Member: 1589326 Status: Offline Sonork: 100.1657227 Thanks Meter: 40 | iphone desabled solution i have iphone4 lost password phone show iphone disebled please any one give me working solution thanksss regardsss |
04-20-2013, 07:22 | #2 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | Just put your iphone in Recovey Or dfu mode and Restore with Itunes, passcode will be removed, all data will be lost too. br |
05-24-2013, 11:42 | #6 (permalink) |
Freak Poster Join Date: Jan 2010 Location: iraq
Member: 1212320 Status: Offline Thanks Meter: 46 | there is 100000% solution for iphone 4 disabled or lost lock code use gecko with win7 and java 6 remember this process will work only for win7 with NET Framework 4 1- remove any java from your computer 2- install java 6 and be sure its version 6 because gecko will not run 3- download and install gecko iphone toolkit from here 4- if gecko automatically run after installation then close it 5- go to Users\your user \AppData\Local\Temp\Gecko_iPhone_Toolkit.exe 6-but your device into dfu mode and from gecko select Bypass iphone disabled 7- select your device model from the list window and click Bypass 8- wait for the progress bar to be shown on the device screen then close the java window 9- a cmd window will appear on computer with yes or no options select n + enter and wait for the reboot now your iphone is asking for the lock code again if you have the code you can just enter it to your iphone and if you don't have it follow the below instructions 1- put your device into dfu mode 2- run Gecko from this directory Users\your user \AppData\Local\Temp\Gecko_iPhone_Toolkit.exe 3-select Read lockscreen password and select iphone model from the list and click boot the you have to select the 5.0.1 IPSW for iphone 4 and click next 4- wait for the big OK to appear on the iphone screen then close redsn0w and click launch 5- wait 10-20 min until you see the code in gecko software note that this will work only if the iphone is locked with simple code ( 4 digits ) and will not worke will the complicated codes believe me i do this 3 or 4 times in every single day and it working if faced any problem with the above steps just tell me and will help you |
06-18-2013, 08:54 | #8 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 431 | Gecko tool kit is required core 2 duo 2.0 processor and 2Gb Ram and if u run gecko tool kit then upgrade ur system... |
The Following User Says Thank You to qasir_amz For This Useful Post: |
