05-20-2011, 16:35 | #5 (permalink) |
Freak Poster Join Date: Jan 2009 Location: Nepal
Member: 952313 Status: Offline Sonork: Coolboy Thanks Meter: 26 | According to your firmware version it is 3G so download 3.1.2 firmware as 3.1.3 firmware not supported to jailbreak with redsnow. 1.Create a folder on your desktop called Pwnage Download RedSn0w-win 0.9.4 and place it in the Pwnage folder. Likewise, download the latest 3.1.2 firmware from below and place it in the same folder. 3.1.2 (3G): iPhone1,2_3.1.2_7D11_Restore.ipsw Extract the RedSn0w application from the RedSn0w zip file to the Pwnage folder. 2. Now launch redsn0w.exe from the Pwnage folder on your desktop. 3.Once RedSn0w opens click the Browse button 4.Even if you are on firmware 3.1.3, still select firmware 3.1.2. Redsn0w works the same way on firmware 3.1.2 or firmware 3.1.3. If you select firmware 3.1.3, you will get an error, as Redsn0w does not recognize the 3.1.3 file yet. Select the firmware ipsw we placed in the Pwnage folder on our desktop then click Open 5.Once the firmware has been verified click the Next button to continue. 6.From this window you can select the jailbreak options you would like. Make sure Cydia is selected. Click the Next button to continue 7.Please plug your iPhone into the computer and make sure its OFF then click the Next button 8.RedSn0w will now guide you through the steps to get into DFU mode. Hold down both the Home button and the Power button for 10 seconds. Release the Power button and continue holding the Home button until RedSn0w detects the device. 9.Your iPhone will now reboot 10.RedSn0w will then begin uploading the new RAM Disk and Kernel. 11.Once this is complete you will be notified that RedSn0w is done. Click the Finish button. After your iPhone finishes rebooting (5 minutes or so), it will be jailbroken with Cydia on the SpringBoard. How To Unlock after jailbreak:- Press to launch Cydia Installer from your SpringBoard. Press to select the Manage tab at the bottom of the screen. Press to select the large Sources button If the ultrasn0w repo is not present press the Edit button at the top right of the screen. Otherwise, skip to Step Nine. Press the Add button at the top left of the screen. Enter ultrasn0w.com as the source url and press the Add Source button. Once the source has been added press the large Return to Cydia button. Press the Done button at the top right of the screen. Press to select repo666.ultrasn0w.com from the list of user entered sources. Press to select ultrasn0w from the list of packages Press the Install button at the top right of the screen Press the Confirm button at the top right of the screen. After installation completes successfully press the large Restart Springboard button. You should now be able to insert the SIM of your choice! |
Z500 Iphone 10 in 1 cables | Nizze | NSPRO | 9 | 04-09-2006 14:53 |
Almost 8GB ++ Europe , Apac , China Samsung Flash file ready for download | MicrostarGSM® | n-Box | 18 | 09-14-2005 20:22 |
Iphone 10 in 1 cabless | cruch | NSPRO | 20 | 08-19-2005 18:20 |
@Adan[iphone] | zeeber | The Market Feed Back | 8 | 08-03-2005 20:22 |
