02-06-2012, 16:32 | #1 (permalink) |
Super Moderator Join Date: Jan 2006 Location: [Egypt, Alex]
Member: 224065 Status: Offline Sonork: 100.1577902 Thanks Meter: 7,930 | iPhone For Dummies 5.0.1 First There's Some Rules When You Work on iPhone : -You Have to Check Before You Work What Version on the iphone and What Baseband Version If iPhone not Activated and You cant Check What Version Try This Simple Application f0recast-v1.3 -If You Have iPhone 3GS or 3G With 6.15 Baseband It's Recommended to Restore With Custom Firmware Or iPhone 4 With Baseband 1.59 YOU MUST INSTALL CUSTOM FIRMWARE if You Want You iPhone Unlocked This Tutorial For Restoring And Working on IOS 5.0.1 Restore: iPhone 4S Just Simple Restore With Original Firmware No Matter What Baseband Because There's No Unlock Solution Till Now You Might Get Error While Restoring Error 3194 Go To C:\WINDOWS\system32\drivers\etc and OPEN host file With notepad and remove Last line should look like this 74.208.105.171 gs.apple.com and Restore Again iPhone 4 -Factory Unlocked Restore With Original Firmware No Matter What Baseband You Might Get Error While Restoring Error 3194 Go To C:\WINDOWS\system32\drivers\etc and OPEN host file With notepad and remove Last line should look like this 74.208.105.171 gs.apple.com and Restore Again -Locked or need Preserved Baseband For 1.59 or 4.10 working on Gevey sim You Have To restore With Custom firmware YOu Can Make it With sn0wbreeze2.9.1 Use Redsn0w To Enter Pwned Mode and Then Restore Either You wont be able to restore If You Get Error 3194 Solution Already posted iPhone 3GS: Error 3194 Go To C:\WINDOWS\system32\drivers\etc and OPEN host file With notepad and remove Last line should look like this 74.208.105.171 gs.apple.com and Restore Again -Locked or need Preserved Baseband For 6.15 or Unlockable Baseband You Have To restore With Custom firmware YOu Can Make it With sn0wbreeze2.9.1 For Some Users 3GS Remains untethered after custom Create Custom Firmware With Preserved baseband only Without jailbreak Use Redsn0w To Enter Pwned Mode and Then Restore Either You wont be able to restore If You Get Error 3194 Solution Already posted iPAD and ipod is The Same Restore Simple Procedure nothing Special Jailbreak: Iphone 4S and iPAd 2: Use absinthe-win-0.4 It's Very simple And Easy iPhone 4 and 3GS : Use redsn0w_win_0.9.10b5 If You Get DONT SEND ERROR When Redsn0w uploading First stage Remove Cable for 3 sec and Reconnect Thanks To Shedid Unlock: For 3GS with baseband 6.15 After Restore You have to install baseband again with redsn0w 10b5 and install ultrasn0w This Tutorial I Made TO Help Users Since i Have to answer the same Question over and over again Please I dont need comments its copy and Paste and It's Already posted and this ......... If You See something Missing or isnt Explained Right be my Guest To Help People I Will Add What Ever i See Missing If You Got Question Please Ask Here Better Making new Thread So We Can Make Complete tutorial Regards, Last edited by ..::Neo::..; 02-24-2012 at 20:06. Reason: thread updates |
The Following 105 Users Say Thank You to ~Leo~ For This Useful Post: |
02-07-2012, 07:52 | #2 (permalink) |
Junior Member Join Date: Feb 2007 Location: Bucharest Age: 34
Member: 450581 Status: Offline Thanks Meter: 3 | Great tutorial ! If I were you, I would add the mention to 3GS unlock, that the newer ones are not safe to update baseband. I know it is also a Sticky, but newcommers seem to be "blind". Cheers, Misujr |
The Following User Says Thank You to misujr For This Useful Post: |
02-07-2012, 15:28 | #3 (permalink) | |
Member: 224065 Status: Offline Sonork: 100.1577902 Thanks Meter: 7,930 | Quote:
I will ADd it but i said if u already have 6.15 after ios 5 reinstall baseband either u will get searching problem | |
The Following 3 Users Say Thank You to ~Leo~ For This Useful Post: |
02-07-2012, 18:23 | #4 (permalink) |
No Life Poster Join Date: Jun 2007 Location: E G Y P T Age: 37
Member: 527884 Status: Offline Sonork: 100.1583794 Thanks Meter: 850 | All Information About Downgrade Will Posted Here Can I Downgrade Basband ? No U Can't Because No Downgrade Solution For Basband Only Solution By Eprom Programmer And Need A Expert And Its Expensive Tools Can I Downgrade Without SHSH ? No U Canot Downgrade Without SHSH Blobs Only 3Gs Can Restore Direct Without SHSH To 4.1 Because Apple Not Stop Signing The Fimware What IS SHSH Blobs Mean ? Its Mean Cydia Have Saved U ECID SHSH File on The Server And U Can Downgrade To This Version Even Apple Stop Signing The Fimware How I Can Save SHSH ? By TinyUmbrella Or By Dumb SHSH By Ifaith Or RedSn0w How I Restore By SHSH ? U Can Restore By Build Signed Fimware By I Faith Or By RedSn0w Or By TinyUmbrella Or Add This Line In Hosts (74.208.105.171 gs.apple.com) But I prefere IFaith Its Very Good And U can Download All From Here http://forum.gsmhosting.com/vbb/f456...wares-1330266/ And IF Any Body See Some thing Else Please Post Here For Any Question Am Here And M.r (AhmedLeopard) Here Very Thanks For AhmedLeopard For Starting The Thread Best Regards B,R Shedeed |
The Following 4 Users Say Thank You to shedeed For This Useful Post: |
02-11-2012, 14:25 | #5 (permalink) |
Junior Member Join Date: Feb 2012 Location: Lebanon
Member: 1721186 Status: Offline Thanks Meter: 6 | How to Convert my iOS 5.0.1 Tethered Jailbreak to iOS 5.0.1 UnTethered Jailbreak STEP 1: Assuming your device is already jailbroken, head to Cydia and leave it till the update is finished. STEP 2: Once updated, search for “Corona 5.0.1 Untether” under BigBoss repository and you’ll be able to download it for free by hitting the “Install” button on the top right of screen. STEP 3 : Once done, you’ll need to reboot your device and get your untethered jailbreak on iOS 5.0.1. |
The Following 3 Users Say Thank You to vista961 For This Useful Post: |
02-17-2012, 05:44 | #6 (permalink) |
Member: 1723203 Status: Offline Thanks Meter: 0 | Really need help Ok so i just bought a iphone 4. Yay! So i thought. Model a1332 emc 380b! How n the world do i jailbreak it?! Im soo aggrivated. Redsnow does not want to download on my windows cpu. I heard snowbreeze is not a good idea but this might be my only hope! Can yu experts PLEASE help me out! And im new to this stuff so i will have alot of questions, if yu dont mind, of course! Thanx in advance!! :-) |
02-17-2012, 06:06 | #7 (permalink) | |
No Life Poster Join Date: May 2008 Location: DHAKA,BANGLADESH
Member: 775086 Status: Offline Sonork: 100.1603609 Thanks Meter: 376 | Quote:
02-17-2012, 15:56 | #9 (permalink) | |
The Following User Says Thank You to ~Leo~ For This Useful Post: |
02-20-2012, 18:17 | #11 (permalink) |
Member: 224065 Status: Offline Sonork: 100.1577902 Thanks Meter: 7,930 | iPhone 3GS: -Factory Unlocked Restore With Original Firmware No Matter What Baseband Because There's No Unlock Solution Till Now You Might Get Error While Restoring @ mods This need to be removed Because There's No Unlock Solution Till Now |
02-21-2012, 23:58 | #12 (permalink) |
Junior Member Join Date: Apr 2011 Location: BiH <3
Member: 1561025 Status: Offline Sonork: wtf is this ? Thanks Meter: 0 | So I did it all like u said in the guide: I have a iPhone 3GS 4.1 bb 6.15 and I wanted to upgrade it to 5.0.1, so I made a custom ipsw with snowbreeze and restored my iphone via itunes with this custom ipsw (so I can unlock it after the restore) , after the restore my screen just went black and my iPhone dont want to boot up anymore... and itunes always recognizes my iphone and says it needs to restore, but when I try to restore it again it gives me error 1600 even if it is already in pwned dfu mode with redsnow...I also tryed to get pwned dfu mode with iReb or snowbreeze (even i tought its the same) but its always the same please help me out dude, i really need my iPhone back... |
02-22-2012, 10:57 | #13 (permalink) | |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
mine is like this: 127.0.0.1 localhost 74.208.10.249 gs.apple.com #127.0.0.1 gs.apple.com which one should i delete?? there are 2 gs.apple.com, and yes, i got error 3194 on my laptop every time i want to restore iphone. please give me some clues. i can only restore iphone/ipod using pc. thanks in advance br | |
02-22-2012, 15:17 | #15 (permalink) | |
Freak Poster Join Date: Dec 2004 Location: Serbia, Belgrade
Member: 100105 Status: Offline Thanks Meter: 24 | iphone Quote:
# mean not active line | |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
