01-09-2014, 04:02 | #2 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2086933 Status: Offline Thanks Meter: 1 | try this... Code: iPhone users occasionally run into a strange error – the 4014 / 4013 – that prevents you from upgrading to latest iOS version via iTunes. Barring OTA updates, any update that is done through iTunes runs the risk of several errors and one of them, the 4013/4014, is our concern here. Put simply, the error is hardware related but like all things digital, you don’t really get to fix this one without your share of head-banging. There are a variety of solutions that worked for various people. What we try here is to make sure you don’t go about trying them randomly but in an ordered way. That makes it easier to fix. Before You Start As always: - Use the latest version of iTunes - Make sure iPhone has enough space to bring in a new update. A gig or more is recommended. - Also make sure the iPhone is not low on battery. The Real Problem Error 4014 (or 4013) is usually associated with a hardware problem – a faulty cable, a faulty port etc. On the surface, your iPhone connects to the computer, iTunes recognizes the device but somewhere down the line, iTunes thinks that the cable is not really that good. Or may be the port isn’t. The first thing you try should be change the USB port to which you connect the iPhone. Next up, change the cable that you use. Arguably, this has worked not for everyone but for a few people. As an extreme measure, you can also try updating from some other computer which has the latest iTunes installed. Backing Up and Going Into Recovery Mode If you are trying to update the firmware without doing a clean restore but running into this error (even after changing the cables), it’s time to cut the chase. This method is usually recommended as the last-thing-to-try but I think it’s easier to get this done with right away. - Connect your iPhone to the computer. Fire up iTunes. - Backup your iPhone. - Now disconnect the iPhone, quit iTunes. - Put the iPhone in recovery mode. The short version goes like this: press and hold power and home buttons till the screen goes blank. - Open iTunes on PC. - Connect the iPhone. iTunes should indicate (through a dialog box) that an iPhone is detected in recovery mode. - Now go ahead and restore the device as new. This will erase everything but you will have the backup to restore from. |
The Following User Says Thank You to eLorDVipeR For This Useful Post: |
01-09-2014, 04:09 | #3 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Change batter , use good usb cable If same Change Phone usb Port I hope your problem solve Br AzimBahar |
The Following User Says Thank You to aZimBahar For This Useful Post: |
