01-31-2011, 01:47 | #1 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1391156 Status: Offline Thanks Meter: 0 | iPhone won't be recognized by computer and now stuck in white circle of death! |
01-31-2011, 02:35 | #2 (permalink) |
No Life Poster Join Date: Apr 2008 Location: TOKYO JAPAN Age: 43
Member: 747968 Status: Offline Sonork: 100.1621353 Thanks Meter: 444 | let your phone with cable connect to computer usb about 1 hr... your phone not dead after that make it dfu and restore it |
01-31-2011, 08:51 | #7 (permalink) |
Member: 1391156 Status: Offline Thanks Meter: 0 | I can't use iReb because my computer won't recognize my iPhone. It won't even load the springboard because i'm stuck with the white circle of death. Is there a hardware modification I can try to fix this? |
01-31-2011, 15:21 | #11 (permalink) |
Freak Poster Join Date: Dec 2008 Location: EARTH
Member: 934525 Status: Offline Thanks Meter: 21 | this must work Disassemble phone then check or replace your iphone connector/charging port then connect to the pc every things should go on well, flash with itunes and then jailbreak. good luck. |
02-04-2011, 10:13 | #15 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Cebu Phils.
Member: 183390 Status: Offline Thanks Meter: 74 | I had encounter such that problem before . What i did was i take out the usb terminal out and clean it. then put it back to dfu mode i use the ireb and it works for me. check the home button of your iphone if its still working if not then you cant get into dfu mode. |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
