Old 05-11-2010, 14:23   #136 (permalink)
Member: 292589
Hi, I have done musclenerd's method but after i install blacksnow from pushfix my phone's REALLY really laggy... fw 3.1.3 bb 5.11.07 with new bootrom...
Old 05-11-2010, 15:13   #137 (permalink)
ameerali19's Avatar
Member: 884639
Sonork: 100.1597105
Thanks Meter: 266
Originally Posted by andy_jpn View Post
iPhone3GS with new boot update to original 3.1.3 keep baseband 05.11.07 100% solution
please do not play this if you don't have original carrier sim card.
this solution needs sim activation on iTunes after update FW
first iTunes flash(update or recovery) fw is build these 2 steps
1.iPhone software(you can see software virsion 3.1.2)
2.iPhone firmware(you can see modem firmware 05.11.07)
The trick is here.
What do you think if you stop flashing when updateing(recovering) manually?
I mean remove cable or burnout or some reasones.
Yes if the stop point is correct you can flash only phone software.
(but if you lost timming to do this then phone firmware will be updated)
1.Open iTunes and connect your iPhone3GS new boot
(unlock must have iPhone has bb05.11.07)
2.Backup your iPhone
3.Restore "iPhone2,1_3.1.3_7E18_Restore.ipsw"
(No need press shift key coz this fw is original)
4.Wait the timming that you remove cable from iPhone.
5.Remove cable NOW when itunes say "restore iphone firmware"
This point is very important
My windows is not english language so iTunes say like this
updating iPhone software
verifying iPhone software
updating iPhone firmware <-- remove cable quickly the massage change to this
6.iTunes gets error 9 but noproblem, don't worry
7.Reboot your iphone(it must goes to recovery mode)
8.Use iH8snow and press "fix recovery mode loop" then choose iPhone 3GS
9.Wait few minuts it will reboot automatic
10.Put carrier sim card and activate on itunes
done
check your version on your iphone
it must be 3.1.3 and 05.11.07
After this you can run SpiritJB
ENJOY and GOOD LUCK
This solution has a risk, play this with own risk!!
andy_jpn
is there any way to understand which is the orginal sim for the handset
i have a iphone 3gs with 3.1.3 (customer bought this seconand)
pls help me
The Following User Says Thank You to ameerali19 For This Useful Post:
Old 05-11-2010, 16:11   #138 (permalink)
Member: 132207
Thanks Meter: 12
please explain more how to do it i am stuck on hi8 its not do any thing.
Old 05-11-2010, 16:24   #139 (permalink)
Member: 292589
Have you install libusb?
Old 05-11-2010, 18:05   #140 (permalink)
Member: 1300813
Did everything right but now can't unlock
I have a 3GS 3.1.3 firmware, but still modem firmware 5.11.07, that I just used Spirit to jailbreak, but now need to unlock. It works fine but now need to unlock
I tried to use Cydia to install Blackrain/blacksnow but after that phone get stuck at reloading data in cydia, then eventually restarts but can’t get past the Apple logo.
Old 05-11-2010, 18:21   #141 (permalink)
Member: 1285120
Thanks Meter: 17
I followed an easier way to unlock my iphone with firmware 3.1.3.
I bought the software!
Source: Unlock easy iDevice
Old 05-11-2010, 19:31   #142 (permalink)
Johnessen's Avatar
Member: 19831
Thanks Meter: 46
How much was the software?
Old 05-11-2010, 21:27   #143 (permalink)
Member: 484676
Thanks Meter: 9
these are scammers, not even think to send money.
Old 05-11-2010, 21:50   #144 (permalink)
https's Avatar
Member: 1263932
Thanks Meter: 181
Source: xxx
There IS NO software for unlock with 05.12.01 modem firmware on iPhone 3GS. If you think you have one, share it and everyone can try. That company only wants your money, but they have no software, otherwise it would be known here.
Old 05-11-2010, 22:14   #145 (permalink)
alexander_bg's Avatar
Member: 10423
Thanks Meter: 15
is there any way to understand which is the orginal sim for the handset?
Old 05-11-2010, 22:22   #146 (permalink)
Member: 1300813
I jailbroke my iphone 3GS using Spirit, and now can't seem to find a way to unlock it. I think I may be safe because my Baseband is still 05.11.07. Anyone know if it can be unlocked?
my iphone details:
Iphone 3GS
OS 3.1.3
BaseBand Ver 05.11.07
Bootloader 06.04
Old 05-11-2010, 23:00   #147 (permalink)
https's Avatar
Member: 1263932
Thanks Meter: 181
my iphone details:
Iphone 3GS
OS 3.1.3
Bootloader 06.04
Open Cydia, add repository, install blacksn0w. For details search for blacksn0w.
Old 05-11-2010, 23:04   #148 (permalink)
https's Avatar
Member: 1263932
Thanks Meter: 181
The "original sim" is the one you initially needed to activate your iPhone. It's the SIM from a carrier that you phone is locked to. You can ask Apple for help if you don't find out otherwise. If you know the model number you can find out where your iPhone comes from (there are lists around, see other threads). It's the SIM from the carrier you use your phone with if it's not unlocked.
If you have an officially unlocked phone (unlocked by Apple or your carrier), then you don't need any "original SIM".
Old 05-12-2010, 05:43   #149 (permalink)
Member: 154483
Thanks Meter: 15
Hi,
Can u share the list of model number..
How can i know which carrier the phone is locked to.
Forcast shows this:
model no. MC159
I guess its from movistar spain but did not work..
thanks
Old 05-12-2010, 05:55   #150 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
Originally Posted by RarePearl View Post
Hi,
Forcast shows this:
model no. MC159
thanks
Official info can be get here: Locating iPhone wireless carriers
Also - you can find a list with factory unlocked in http://forum.gsmhosting.com/vbb/5465512-post14.html
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.26364 seconds with 10 queries
