Old 11-10-2010, 17:48   #1 (permalink)
Member: 208901
Question iPhone4 Power Problem who can solve this urgent?
Dear Friends,
I received iphone4 as dead, when i opened & removed battery connection and put it back phone started work fine.. without any problem..
But if i switched off couple of hours then again want to switch ON, it will not power on. untill i removed battery connecton & put it back then only will start working.
some time this will happen (i mean wont power on until remove batery connection & put it back) in couple of days or couple of hours and some time if i switch off and want to switch on in 30 minutes/ an hour. it wont switch on. until i removed & fixed back battery connection again.
1. already restored 3- 4 times with 4.1 version.
2. changed battery
3. Complete PCB fixed in other working unit.
Still same problem occurs.
Thanks in advace for your valuable exprience to share here.
Regards,
NOKIA0077
Old 11-10-2010, 18:31   #2 (permalink)
ebry's Avatar
Member: 127240
Thanks Meter: 82
Did you tried your motherboard in the other phone?
Old 11-10-2010, 18:46   #3 (permalink)
Member: 208901
Dear Ebry,
i told that in point # 3. as i took a working unit and took that defective mother board and fixed in other unit . but still holds same problem..
Old 11-11-2010, 06:34   #4 (permalink)
Member: 208901
Dear Friends,
its related with Main Board only. but what to check and where to check.. plz... advise..
Thanks
Old 11-12-2010, 13:36   #5 (permalink)
Member: 208901
Still waiting replies about this power problem. where are the iphone experts???
Old 11-12-2010, 13:46   #6 (permalink)
robin25's Avatar
Member: 771565
Sonork: 100.1656305
Thanks Meter: 145
Lightbulb okey
check battery power and all connector
may be not attached well
Old 11-12-2010, 13:48   #7 (permalink)
biaby's Avatar
Member: 523332
Thanks Meter: 273
100 % power IC,if you can deal with it then it's good and please if you find where it is,
please post a picture of it here.
good luck br,
Old 11-12-2010, 13:54   #8 (permalink)
biaby's Avatar
Member: 523332
Thanks Meter: 273
ok ic number is :338S0867 try to find it in your mother board.
good luck
Old 11-12-2010, 14:48   #9 (permalink)
smorbe's Avatar
Member: 132735
Thanks Meter: 88
when the phone power off and not able to power on did you try to put usb into pc?
does your pc detect phone when off?
Old 11-12-2010, 15:34   #10 (permalink)
Member: 208901
@ smorbe
when its unable to switch on also not detecting on PC thru USB cable..
@biaby
what to do with Power IC you mean to change it or reball or just give some heat to this IC?
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Page generated in 0.18379 seconds with 10 queries
