Old 12-16-2012, 14:41   #1 (permalink)
Member: 771979
Sonork: 100.1676605
Thanks Meter: 55
iPhone4 Stuck on recover mode , Error occurred (-1) - any help please !!
Hi,
i have iphone4 stuck on recover mode when i try to restor with latest os get error
this error
The iPhone "iPhone" could not be restored. An unknown error occurred (-1).
check attachment pic upload any idea
Old 12-16-2012, 14:48   #2 (permalink)
Cheater -Don't Deal with him-
Member: 1236325
Sonork: 100.1616831
Thanks Meter: 272
open latest redsn0w_win_0.9.15b3 --- go to extras --- Recovery FIX ( put ur iphone in DFU mode to use this section ) and ur problem will be solved 100%.
Old 12-16-2012, 15:02   #3 (permalink)
Member: 479086
Thanks Meter: 399
Hardware issue
Baseband / IMEI / Wifi / Bluetooth is Gone
Old 12-16-2012, 15:02   #4 (permalink)
Member: 479086
Thanks Meter: 399
Hardware issue
Old 12-16-2012, 15:10   #5 (permalink)
Member: 1121501
Thanks Meter: 2
i go with this answer 1st check this
The Following User Says Thank You to mani_mani_4 For This Useful Post:
Old 12-16-2012, 15:12   #6 (permalink)
Member: 771979
Sonork: 100.1676605
Thanks Meter: 55
same already tryed
error on redsnow
missing Keys.plist data for this build:
Device: iPhone
ECID:   73300229455
Build:  iphone3,1_6.0.1_10A523
Old 12-16-2012, 15:21   #7 (permalink)
<<::GS|\/|SAGA::>>'s Avatar
Member: 194936
Sonork: 100.1616223
Thanks Meter: 484
bro 100% hardware imei 000000000000
Old 12-16-2012, 15:29   #8 (permalink)
Member: 771979
Sonork: 100.1676605
Thanks Meter: 55
imei is not 000
just write custom firmware
sn0wbreeze_iPhone_4-GSM-6.0.1-10A523
this now phone is on activation screen and i have checked imei all is ok wifi is also working but now activation problem
please visit a Apple Store or call apple care at 0870 876 0753
Old 12-16-2012, 15:32   #9 (permalink)
..::Nokian CareŽ::..'s Avatar
Member: 505794
Sonork: 100.1627614 QQ:1958018248
Thanks Meter: 2,266
Originally Posted by Salman Raisi View Post
imei is not 000
don't worry dear this recovery problem plz redsn0w to getout from here
Old 12-16-2012, 15:33   #10 (permalink)
Member: 771979
Sonork: 100.1676605
Thanks Meter: 55
check these attachment pics
The Following User Says Thank You to Salman Raisi For This Useful Post:
Old 12-16-2012, 15:58   #11 (permalink)
sjd012's Avatar
Member: 1835240
Sonork: 100.1624260
Thanks Meter: 26
resnow 15b3 problem will be solved 100%.
Old 12-16-2012, 18:04   #12 (permalink)
Member: 771979
Sonork: 100.1676605
Thanks Meter: 55
plz chek post number 6 already tryed
any other solution ?
Old 12-16-2012, 19:39   #13 (permalink)
GSM-DOCTOR's Avatar
Member: 604333
Sonork: 100.1590054
Thanks Meter: 1,845
Hi,
this error
Error -1 means baseband issue
And you can only get out from recovery by using custom firmware
Use sn0wbreeze to creat a custom activated firmware
Note: the base band issue will remain because baseband is a physical (hardware) problem
GSM-DOCTOR
Old 12-17-2012, 00:49   #14 (permalink)
Member: 1236325
Sonork: 100.1616831
Thanks Meter: 272
same already tryed
error on redsnow
Device: iPhone
ECID:   73300229455
Bro u need to select manually ipsw and u need to choose ipsw 6.0 then try to fix recovery will solve thi problem it's not hardware problem i solve many iphone with this solutions only iphone 4S not solved for iphone 4 all iphone that have gd imei and have error -1 open latest redsn0w choose ipsw manual 6.0 not 6.0.1 and will work gr8 fix recovery
Old 12-17-2012, 04:18   #15 (permalink)
Member: 505794
Thanks Meter: 2,266
Yes i agree with u infact i also done many times but if this tutorial can't solve this problem then ur modem chip is damged and no help at this time
Sent from my HTC One X using Tapatalk 2
The Following User Says Thank You to ..::Nokian CareŽ::.. For This Useful Post:
Page generated in 0.33110 seconds with 9 queries
