03-08-2014, 12:55 | #1 (permalink) |
Insane Poster Join Date: Dec 2013
Member: 2087782 Status: Offline Thanks Meter: 6 | iphone4s after replace screen alwase searching |
03-08-2014, 14:07 | #3 (permalink) |
Freak Poster Join Date: Feb 2007 Location: at the top of u
Member: 455794 Status: Offline Sonork: 100.1591235 Thanks Meter: 61 | set auto date and time to off state and enter manually to the correct current date and time i.e 08 mar 2014 if it the same try to insert 64k sim i think you will get network then insert the previous sim |
03-08-2014, 23:33 | #6 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Inside Brain Age: 39
Member: 239956 Status: Offline Thanks Meter: 68 | Just connect iTunes or just change time correctly and region you live.....remove Sim Cart and insert again .....Except you did something wrong wile changing LCD something damaget or......... |
03-11-2014, 09:15 | #9 (permalink) |
Member: 2087782 Status: Offline Thanks Meter: 6 | [QUOTE=missou;10154685]connect to itunes for syncing cause your date returned to 1970 . after that reboot your phone problem solved[/QUOT my problem not solved.i do all of these set date and time manually bot not solved alwase show searching.i connect with itune and update also but same .i m 100% sure that it is not hardware daimej problem becoz today i again dissemble another iphone 4s after that it is also go in searching mode.i haved fase this type of problem in 4 but after set date and time network come but in 4s not solved |
