Old 09-13-2011, 18:15   #1 (permalink)
Member: 520110
Thanks Meter: 44
ipod is Disabled 3
i try with ituns and always i get err plz give me the perfect solution
Old 09-13-2011, 18:26   #2 (permalink)
Member: 1042823
Thanks Meter: 14
1- make i pod at fdu mode
2- connect with i tunes
3_click restore
its ok
The Following User Says Thank You to h.puzzel For This Useful Post:
Old 09-14-2011, 07:02   #3 (permalink)
Member: 776360
Sonork: nothing
Thanks Meter: 4
ipod is disabled that same problem
how to make fdu mode
when it restore mode in itunes error will be indicate 3194
so pls help me
waiting for your reply
The Following User Says Thank You to vinothbrs_trl For This Useful Post:
Old 09-14-2011, 07:21   #4 (permalink)
Member: 637642
Sonork: 1610072
Thanks Meter: 47
so pls help me
DFU mode = Device Firmware Update mode
DFU mode is a mode where the iPod Touch/iPhone will be made to force a restore of the firmware into whatever version firmware it is given.
Getting your iPod Touch/iPhone into DFU mode is somewhat tricky, and it may require some patience/practice because timing is essential to get it to DFU mode and not into recovery mode.
1. First, Open up iTunes, plug in your iPod Touch/iPhone to the CPU's USB port. Turn on your CPU's speaker and make sure it is loud enough that you can hear it.
2. Hold down the Home button (top left for iPod Touch and top right for the iPhone with the screen facing you) and the Power button (located on the front bottom of your iPod Touch/iPhone) simutaneously, until the screen goes black and the device turns off. (past the red slider/slide to power off screen)
3. Now let go of the Power button, but continue to hold the Home button. Your iPod Touch/iPhone should have turned off and the screen should not be on.
4. After around ~10-20 seconds, you will hear a noise (beep/ding) from your CPU as if it had just recognized a new hardware device, now iTunes should recognize it in DFU mode.
5. After iTunes recognizes the iPod Touch/iPhone, let go of the Home button otherwise it will go into recovery mode and you will have to do the entire DFU process over again.
6. You will know when you have put your iPod Touch/iPhone correctly into DFU mode when the display is blank and that you do not have anything on your device.
And you are done, now you can install any iPod Touch/iPhone firmware on to your device via the iTunes SHIFT recovery method
The Following User Says Thank You to .::ali-1::. For This Useful Post:
Old 09-14-2011, 08:57   #5 (permalink)
Member: 776360
Sonork: nothing
Thanks Meter: 4
thank to say .::ali-1::..........
when using shift to that firmware is not suitable how to check that suitable firmware pls tel me
next
direct when recovery method in itunes
my ipod touch itunes error will be indicate 3194
"ipod is disabled connect to itunes" screen will be locked no working how to recover & unlock this pls give an idea am wating for your reply
Old 09-14-2011, 09:26   #6 (permalink)
rahulk99k's Avatar
Member: 485686
Thanks Meter: 539
(1) put your device on DFU mode
(2) open ireb then choose ipod 2/3/4
(3) after done on ireb open itunes restore it with latest firmware.
dfu helper DFU Video - YouTube
ireb Hotfile.com: One click file hosting: iREB-r4.zip
firmware » felixbruns.de
The Following User Says Thank You to rahulk99k For This Useful Post:
Old 09-14-2011, 21:01   #7 (permalink)
Member: 520110
Thanks Meter: 44
problem fxed with yr solution thank all of you for your help
but i wan to know how i can instal Cydia in may Ipod ( ipod 3 version 4.3.5)
thak's
Old 09-15-2011, 19:52   #8 (permalink)
Crazy Poster
Member: 1128147
Thanks Meter: 2
pls guys help i have ipod that is lock with password and and cannot connet to itune what do i do pls help
Old 09-15-2011, 19:56   #9 (permalink)
EJAZGUL's Avatar
Member: 638481
Sonork: 100.1601053
Thanks Meter: 749
thak's
u can with redsn0w bt it will be tethered
if u still want to jailbreak than tel me i will try to help u
Old 09-15-2011, 19:58   #10 (permalink)
EJAZGUL's Avatar
Member: 638481
Sonork: 100.1601053
Thanks Meter: 749
enter in DFU mode than restore ur ipod
it will be done
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
sp lock 1,2,3,4 removed spterminator Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 10 08-09-2010 10:20
2,000 for 5110/6110 unlock software 1 2 3 4 Dean O'Grady Wanted Products 14 03-19-2005 09:52
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE 40 (1+) -- 30 (20+) andrew bennett Main Sales Section 1 07-26-1999 19:33
Page generated in 0.35587 seconds with 8 queries
