01-22-2012, 08:44 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: BANGLADESH
Member: 571956 Status: Offline Thanks Meter: 496 | Ipod hardware reset Ipod hardware reset Solved: How to reset iPod nano, 1st 2nd, 3rd, 4th, 5th generation, iPod classic, iPod photo, iPod mini reset: Toggle the Hold switch on and then off. Press and hold the Menu and... To reset an iPod with a Click Wheel, including: 1. Toggle the Hold switch on and then off. 2. Press and hold the Menu and Center (Selection) buttons simultaneously until the Apple logo appears, about 6-8 seconds. You may repeat it several times. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. |
01-22-2012, 08:47 | #2 (permalink) |
Member: 571956 Status: Offline Thanks Meter: 496 | To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) 1. Toggle the Hold switch on and then off. 2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6-8 seconds. You may repeat it several times. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. To return iPod to its original factory settings, use the iPod Software Updater utility to restore iPod. You can download it from Apple website. |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
how can you reset the life timer without using a data cable for a 5125 TDMA phone? | PiNoY_bOy204 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-23-2001 12:46 |
5110 hardware prblem ( battery drain fast) | Fai555 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-09-2001 03:06 |
HOW TO RESET SECURITY CODE IN NOKIA 6210 | ed2k_7 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 05-26-2001 05:33 |
5110 5.28 Hardware solution | Ringnet | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 18 | 06-27-2000 14:09 |
