Old 11-03-2011, 00:57   #1 (permalink)
Member: 1134862
Thanks Meter: 25
iTunes Error 1 - Can't fix !
First,hi all.
I have an iPhone 4 and i'll try to update it to 4.3.5 with shsh blobs,it goes about 70% of the process of updating,then stops and iTunes shows me error (1).Then I try to restore with 4.2.1 (shsh blobs saved) same error.The only way to get out from this error after it has been shown on iTunes,is with redsn0w (new version 0.9.9b7),to jailbreak the iPhone and then everything works well.
But,i want to update to 4.3.5 to update my baseband to 4.10 but with iTunes showing error 1 it can't be done.
Every suggestion would be appreciated.
Thank (hope i was clearly enough with the explanation of the problem)
Old 11-03-2011, 01:02   #2 (permalink)
Member: 179453
Thanks Meter: 29
Same Problem!!!
Yesterday 1 Iphone 3GS 8GB and Today 1 Iphone 3GS.
After downgrade with itunes no imei no wifi no bluetooth and only -1 error shows me in Itunes.
PLEASE HELP US
Old 11-03-2011, 01:38   #3 (permalink)
Member: 1478135
you can fix the error 1 in itunes it's like 1013,what your shsh saved version?
Old 11-03-2011, 10:40   #4 (permalink)
Member: 1134862
Thanks Meter: 25
el.elkihal
tried the methot of 1013 for fixing error 1 but now i get error 3194.
I have SHSH for 4.2.1 and 4.3.5.
Old 11-03-2011, 10:48   #5 (permalink)
Crazy Poster
Member: 1540273
Thanks Meter: 2
Try loading 4.1 in DFU mode.(start TSS server in Tiny Umbrella while restoring.
Old 11-03-2011, 11:14   #6 (permalink)
bontek's Avatar
Member: 835
Thanks Meter: 42
Use custom firmware to downgrade and use ONLY Saurik server IP in hosts file
After it use fixrecovery
Thqts all
Old 11-03-2011, 11:18   #7 (permalink)
wong edan's Avatar
Member: 775581
Thanks Meter: 186
Thqts all
what's saurik server IP please.....
Old 11-03-2011, 11:53   #8 (permalink)
Member: 1134862
Thanks Meter: 25
Custom firmwares does not update baseband.I want to update the baseband to 4.10,but i can't because i get error 1.This error stops the baseband upgrade.That's the problem.
Old 11-03-2011, 12:43   #9 (permalink)
Member: 1134862
Thanks Meter: 25
Tons of users,and nobody can help you :/
I am sure that i'm not the only one who has this problem !
Old 11-03-2011, 13:07   #10 (permalink)
nik
nik's Avatar
Member: 127
Thanks Meter: 30
this is very common error since new itunes and ios 5 is released ,but theres no solution published for this yet .
for 3gs no soution found .
for 4 you simply deactivate after complete restore with ios5 .
reg
Nik
Old 11-03-2011, 14:11   #11 (permalink)
Member: 1315082
Thanks Meter: 16
its challenge for dev-team !!!
The Following User Says Thank You to ravibalani_5 For This Useful Post:
Old 11-12-2011, 23:12   #12 (permalink)
Member: 20024
Anyone fixed this problem?
I have an iphone 4 that I am trying to restore. But I always get error 1 and after that it goes in recovery mode
Old 11-13-2011, 00:55   #13 (permalink)
Member: 14663
Thanks Meter: 6
HI,
if you need fixed this problem
after you get error 1
use redsn0w last version
go xtras/select IPSW&chois your restor file&chois recovery fix, then next &go iphone dfu mode
wait 12 minets, no your iphone powre normal put you cant downgread the baseband.
B.R
The Following User Says Thank You to asem For This Useful Post:
Old 11-13-2011, 02:55   #14 (permalink)
Member: 1180332
use fix recovery for 4.2.1.. to fix error 1....
Old 11-13-2011, 06:42   #15 (permalink)
.::SOLUTION::.'s Avatar
Member: 1653223
Sonork: 100.1619309
Thanks Meter: 146
Error 1
Unable to downgrade. Try changing the USB port (the back one of chassis is better) and restart computer.
The installed version of iTunes may also be too old. Update iTunes.
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.22649 seconds with 10 queries
