01-01-2014, 14:49 | #17 (permalink) |
Junior Member Join Date: Aug 2007
Member: 564810 Status: Offline Thanks Meter: 10 | Check R61 and R153 I had error 29 Check R61 and R153 next to battery connector they are 0 ohm resistor links that go to U52 and tell the chip the state of the battery. if either of these are broken or cracked, the restore will fail at about 70% with error 29 check your restore log... 'RamrodErrorDomain/3ea: update_gas_gauge: gasgauge_swupdate returned -1' Replacing or bridging these resistors wil fix it. It worked for me anyway. Hope it helps |
The Following 3 Users Say Thank You to tacromx For This Useful Post: |
01-21-2014, 16:16 | #19 (permalink) | |
Junior Member Join Date: Dec 2010
Member: 1468567 Status: Offline Thanks Meter: 3 | Quote:
Thanks Tacromx, R153 was broken, happy days | |
05-20-2014, 16:52 | #24 (permalink) |
Member: 564810 Status: Offline Thanks Meter: 10 | the solution i posted was for Iphone 4S not Iphone 4 , but the solution will be the same, download 4S schems as well as 4, find the resistors on the 4s schem and try to find the equivelent on the 4 schem |
10-19-2014, 08:18 | #29 (permalink) |
Banned Join Date: Oct 2014 Location: india ( Punjab )
Member: 2271772 Status: Offline Sonork: 100.1672706 Thanks Meter: 45 | Iphone 4 restore error 3194 on ios7.0.2 Dear if u face this eroor first Overwrite the Host File ,ur old host file avaiable in ur C: DRIVE SELECT THEN NEW HOSTFILE WHERE IS LOCATED AND REPLACE IT IF U NEED U CNA CONTNAT WITH US I WILL PROVIDE THE HOST FILE 100% UR PROBLEM SOLVE LIKE 3194 Error Thanks |
The Following User Says Thank You to softmind For This Useful Post: |
