-   iPhone 4 / iPhone 4S (http://forum.gsmhosting.com/vbb/f456/)
-   -   itunes , error 29 , iphone 4s help required ..[solved] (http://forum.gsmhosting.com/vbb/f456/itunes-error-29-iphone-4s-help-required-solved-1720062/)
mighelon 09-27-2013 14:04
the phone had working well for 2 mounts and when y tried to upgrade it to iOS 7 its given me error 29 , whith the original battery the same thing happens :mad: , the phone its now in recovery mode , could anyone give me please a solution ??
tanks
shashankmobile 09-27-2013 14:42
Error 20, 21, 23, 26, 28, 29, 34, 36, 37, 40
These errors typically occur when security software interferes with the restore and update process. Use the steps to troubleshoot security software issues to resolve this issue. In rare cases, these errors may be a hardware issue. If the errors persist on another computer, the device may need service.
Also, check your hosts file to verify that it's not blocking iTunes from communicating with the update server. See the steps under the heading "Blocked by configuration (Mac OS X / Windows) > Rebuild network information > Mac OS X > The hosts file may also be blocking the iTunes Store." If you have software used to perform unauthorized modifications to the iOS device, uninstall this software prior to editing the hosts file to prevent that software from automatically modifying the hosts file again on restart.
Br.
Shashank
Gerti 09-27-2013 17:36
i have the same problem how can we solve it ?
biaby 09-27-2013 18:16
here i have the same probleme with iphone 4 s .
PlayGsm 09-29-2013 19:02
I have same problam plz any one help
Iphone 4 restore error 3194 on ios7.0.2
mighelon 10-01-2013 17:46
you dont have the same problem , please create your own post ..
alkhaleejmobile 10-26-2013 20:58
its mostly hw,,issue,,i have ,recover it by shake ,or rebal.base band chip..u can try,,
by.lorenc 10-26-2013 23:31
i have the same problem error 29 on iphone 4s.....????
kissofdragon143 10-27-2013 18:57
itunes error 29 fix
bro just add # in urs host file(#74.208.10.249 gs.apple.com) work like charm for me.
cooloxf 10-31-2013 10:47
I have same problem plz any one got solution
Iphone 4 restore error 29 on ios7.0.3
thank's
goku_0729 11-02-2013 13:09
error 29 is battery issue try to replace battery w/ 80 percent charge or replacee a new one for error 3194 ios 7.0.2 is software issue because 7.0.2 is stop signing in server. better go for latest ios 7 of apple.
sumon39 12-05-2013 06:47
i have same problem. iphone 4s error29 pls any solution
bunty1 12-05-2013 06:50
change new battery and update again 100% slove
anarquia89 12-05-2013 06:51
battery problem change
nishu617 12-08-2013 12:49
help me with this same error 29 iPhone 4S
installed new battery from my other iPhone a4s but I get again and again error 29
I am installing 7.0.4 as my phone is in recovery mode since last 10 days and it's is a paper weight now:mad:mad:
Page generated in 0.26155 seconds with 5 queries
