-   iPhone 4 / iPhone 4S (http://forum.gsmhosting.com/vbb/f456/)
-   -   itunes , error 29 , iphone 4s help required ..[solved] (http://forum.gsmhosting.com/vbb/f456/itunes-error-29-iphone-4s-help-required-solved-1720062/)
eugen 12-28-2013 17:54
Originally Posted by nishu617 (Post 9937265)
help me with this same error 29 iPhone 4S
installed new battery from my other iPhone a4s but I get again and again error 29
I am installing 7.0.4 as my phone is in recovery mode since last 10 days and it's is a paper weight now:mad:mad:
hello bro. i've just fixed that error just change the battery from an other ip4s everything will be fine. try to restore it. hope it helps.:):);)
tacromx 01-01-2014 13:49
Check R61 and R153
I had error 29
Check R61 and R153 next to battery connector they are 0 ohm resistor links that go to U52 and tell the chip the state of the battery.
if either of these are broken or cracked, the restore will fail at about 70% with error 29
check your restore log...
'RamrodErrorDomain/3ea: update_gas_gauge: gasgauge_swupdate returned -1'
Replacing or bridging these resistors wil fix it. It worked for me anyway.
Hope it helps ;)
vlatche_mk 01-04-2014 15:32
i had this error. try with new battery. worked for me.
jeppea 01-21-2014 15:16
Originally Posted by tacromx (Post 9990145)
I had error 29
Hope it helps ;)
Thanks Tacromx, R153 was broken, happy days :)
drahimik 01-23-2014 09:49
I have same problem , how can i know withch battery is correct , i have now 616-0580 , i have to put same or more new one,
tacromx 01-23-2014 17:00
i have 616-0579 battery, 616-0580 is the same so should work
if it does not, see my previous post above for possible solution
good luck
mohsin_mmp1 02-01-2014 15:00
error 29 software problem
remove all other usb
remove all other devices
update ur itunes
change cable
it will work
Shoaib1989 05-18-2014 08:59
Can u send me a snapshot of these resistors i cant locate these in schematics. I have a iPhone4 in recovery mode connect to itunes its stuck on 70% while restore n shows error 29. Pls help
tacromx 05-20-2014 16:52
the solution i posted was for Iphone 4S not Iphone 4 , but the solution will be the same, download 4S schems as well as 4, find the resistors on the 4s schem and try to find the equivelent on the 4 schem
Amankhan1992 07-11-2014 07:23
Who Can Help Me 29 Error I phone 4s Call Me Viber 0779450024
zeeshan2000 07-11-2014 15:12
change battry 100% solution for error 29
mhasant2 08-15-2014 16:04
just try with a full charge battery for error 29
100000000000000000000000000% sure
it will be solve ur problem
sachin kumar sh 10-18-2014 14:01
i change the battery but problem still
softmind 10-19-2014 08:18
Iphone 4 restore error 3194 on ios7.0.2
Dear if u face this eroor first Overwrite the Host File ,ur old host file avaiable in ur C: DRIVE
SELECT THEN NEW HOSTFILE WHERE IS LOCATED AND REPLACE IT
IF U NEED U CNA CONTNAT WITH US I WILL PROVIDE THE HOST FILE
100% UR PROBLEM SOLVE LIKE 3194 Error
Thanks
DEEPAK_ATOZ 11-04-2014 15:52
10000000000%
Perfect answer 100000000000% tested by me
Thx Mate:):):):)
Page generated in 0.28584 seconds with 5 queries
