-   iPhone 4 / iPhone 4S (http://forum.gsmhosting.com/vbb/f456/)
-   -   itunes , error 29 , iphone 4s help required ..[solved] (http://forum.gsmhosting.com/vbb/f456/itunes-error-29-iphone-4s-help-required-solved-1720062/)
sonofone143 11-08-2014 07:56
i also have the same problem how can we solve it ?
have same problem. iphone 4s error29 pls any solution?
sonofone143 11-08-2014 07:58
I have same problam plz any one help
Iphone 4 restore error 3194 on ios7.0.1
beleo 12-06-2014 15:35
i think its an battery problem, try change it with an genuine battery and not aftermarket one, i think it will work
ameerali19 01-08-2015 08:23
http://i1179.photobucket.com/albums/...psa23a54d6.png
kharimobiles 01-12-2015 10:27
i have the same problem error 29 on iphone 4s.....????
amersoft 03-09-2015 09:00
hi
sorry for my bad english!
yes, it is battery problem.
simplest way is replacing battery.
but let's be pro.
the gas gauge wire on the flex makes the problem. because it's at outer side of flex cable and is very thin and disconnects easily.
if someone has a healthy iphone 4s battery, share the connection way from socket to battery board. so we'll can do wiring.
chamronggsm 05-01-2015 10:03
My iphone 4s error 29 the same ????
..::KASHIF::.. 06-02-2015 20:20
change battry 100% solution for error 29
i test
1000000% work
not sol chek Video hadrwer
https://www.youtube.com/watch?v=wOXmrFnDnQI
stefanodave 07-22-2015 10:46
I have same problem. I have try to replace the battery, all condesator beep and found In the right position (R153 R61 ecc). The only thing I noticed is that the phone does not remain open with the battery attached , but have to be connected to a charger to power up in recovery mode
wahablepirate 12-16-2015 14:58
How you did to solve it?
Originally Posted by deepak_atoz (Post 10657865)
perfect answer 100000000000% tested by me
thx mate:):):):)
how you did to solve it please .
Thanks in advance
candra2606 03-28-2016 08:25
this hardware problem
try change battery
if still not working try Remove Battery and check the battery ways, there are 4 caps. Make sure that they are all in place and not damaged or corroded. If they are all in place you will need to replace the PMIC on motherboard. If you see damage to caps then you can simply remove them off a different motherboard and add to the phone you are trying to fix.
celltellpb 03-30-2016 16:18
The problem is battery
Tested and aprovved
samicool88 04-06-2016 09:06
i try change battery and r153 nd r61 but not slove error 29
pls help
harman5560 04-18-2016 09:33
change battery 100% Tested 29 eror fix
Page generated in 0.27293 seconds with 5 queries
