101% battery problem if the resistor and capasitor is working. tried it many times. replace it wityh original iphone 4s battery not class a or else u get error 29 |
Best Regards |
change battery 10000000%ok or charge the battery in other cellphone above 60% and insert back then flash ,,,, DONE |
Change new battery and update again 100% slove |
txs fixed with original battery fully charged |
all u need good batary |
Battery Cahnge 100% Solve. Tested on Iphone 4s |
my same problam .. 4s 16 error |
ipad 2 3g+wifi error -1 |
solve chnage original battery 100% solved |
Fainaly done change battery |
battery problem change the battery and make restore |
i phone 4s error 29 first check bettery second check charging flex third check camera and other flex just unplug them and put them back try now 100% done |
check battery connects ways and battery |
change the battery and the problem solved error 29 with 2 iPhone |
