Old 12-28-2013, 17:54   #16 (permalink)
Member: 140959
Thanks Meter: 9
Originally Posted by nishu617 View Post
help me with this same error 29 iPhone 4S
installed new battery from my other iPhone a4s but I get again and again error 29
I am installing 7.0.4 as my phone is in recovery mode since last 10 days and it's is a paper weight nowmad:
hello bro. i've just fixed that error just change the battery from an other ip4s everything will be fine. try to restore it. hope it helps.
Old 01-01-2014, 13:49   #17 (permalink)
Member: 564810
Thanks Meter: 9
Thumbs up Check R61 and R153
I had error 29
Check R61 and R153 next to battery connector they are 0 ohm resistor links that go to U52 and tell the chip the state of the battery.
if either of these are broken or cracked, the restore will fail at about 70% with error 29
check your restore log...
'RamrodErrorDomain/3ea: update_gas_gauge: gasgauge_swupdate returned -1'
Replacing or bridging these resistors wil fix it. It worked for me anyway.
Hope it helps
The Following 2 Users Say Thank You to tacromx For This Useful Post:
Old 01-04-2014, 15:32   #18 (permalink)
Member: 385755
Thanks Meter: 3
i had this error. try with new battery. worked for me.
The Following User Says Thank You to vlatche_mk For This Useful Post:
Old 01-21-2014, 15:16   #19 (permalink)
Member: 1468567
Thanks Meter: 2
Originally Posted by tacromx View Post
I had error 29
Hope it helps
Thanks Tacromx, R153 was broken, happy days
Old 01-23-2014, 09:49   #20 (permalink)
Member: 2112607
I have same problem , how can i know withch battery is correct , i have now 616-0580 , i have to put same or more new one,
Old 01-23-2014, 17:00   #21 (permalink)
Member: 564810
Thanks Meter: 9
i have 616-0579 battery, 616-0580 is the same so should work
if it does not, see my previous post above for possible solution
good luck
Old 02-01-2014, 15:00   #22 (permalink)
Member: 1992469
Sonork: 100.1622570
Thanks Meter: 4
error 29 software problem
remove all other usb
remove all other devices
update ur itunes
change cable
it will work
Old 05-18-2014, 08:59   #23 (permalink)
Member: 639546
Thanks Meter: 4
Can u send me a snapshot of these resistors i cant locate these in schematics. I have a iPhone4 in recovery mode connect to itunes its stuck on 70% while restore n shows error 29. Pls help
Old 05-20-2014, 16:52   #24 (permalink)
Member: 564810
Thanks Meter: 9
the solution i posted was for Iphone 4S not Iphone 4 , but the solution will be the same, download 4S schems as well as 4, find the resistors on the 4s schem and try to find the equivelent on the 4 schem
Old 07-11-2014, 07:23   #25 (permalink)
Member: 1734037
Sonork: 100.1617238
Who Can Help Me 29 Error I phone 4s Call Me Viber 0779450024
Old 07-11-2014, 15:12   #26 (permalink)
Member: 1628273
Thanks Meter: 3
change battry 100% solution for error 29
Old 08-15-2014, 16:04   #27 (permalink)
Member: 1639593
Sonork: 100 1622630
Thanks Meter: 6
just try with a full charge battery for error 29
100000000000000000000000000% sure
it will be solve ur problem
Old 10-18-2014, 14:01   #28 (permalink)
Member: 212545
Sonork: 100.1669621
Thanks Meter: 5
i change the battery but problem still
The Following User Says Thank You to sachin kumar sh For This Useful Post:
Old 10-19-2014, 08:18   #29 (permalink)
Member: 2271772
Sonork: 100.1672706
Thanks Meter: 26
Iphone 4 restore error 3194 on ios7.0.2
Dear if u face this eroor first Overwrite the Host File ,ur old host file avaiable in ur C: DRIVE
SELECT THEN NEW HOSTFILE WHERE IS LOCATED AND REPLACE IT
IF U NEED U CNA CONTNAT WITH US I WILL PROVIDE THE HOST FILE
100% UR PROBLEM SOLVE LIKE 3194 Error
Thanks
The Following User Says Thank You to softmind For This Useful Post:
Old 11-04-2014, 15:52   #30 (permalink)
DEEPAK_ATOZ's Avatar
Member: 349089
Thanks Meter: 110
Lightbulb 10000000000%
Perfect answer 100000000000% tested by me
Thx Mate
Page generated in 0.38211 seconds with 7 queries
