Old 05-11-2016, 06:37   #46 (permalink)
Member: 1672489
101% battery problem if the resistor and capasitor is working. tried it many times. replace it wityh original iphone 4s battery not class a or else u get error 29
Old 05-11-2016, 06:47   #47 (permalink)
Member: 2558455
Thanks Meter: 5
Smile
brother its 100% battery problem change battery from other working iphone 4s battery will charged minimum 80%
Best Regards
Old 05-13-2016, 11:50   #48 (permalink)
Member: 1754160
Sonork: 100.1621741
change battery 10000000%ok or charge the battery in other cellphone above 60% and insert back then flash ,,,, DONE
Old 05-25-2016, 13:06   #49 (permalink)
Anamul.2014's Avatar
Member: 2145140
Sonork: 100.1650938
Thanks Meter: 90
Change new battery and update again 100% slove
Old 06-15-2016, 15:56   #50 (permalink)
Member: 1487405
Thanks Meter: 31
txs fixed with original battery fully charged
Old 06-21-2016, 22:37   #51 (permalink)
Member: 141922
Sonork: 1616910
all u need good batary
Old 07-31-2016, 11:48   #52 (permalink)
Member: 2411409
Sonork: 1000.2
Thanks Meter: 14
Battery Cahnge 100% Solve. Tested on Iphone 4s
Old 08-05-2016, 06:25   #53 (permalink)
Member: 2550445
Thanks Meter: 14
my same problam .. 4s 16 error
Old 08-05-2016, 07:33   #54 (permalink)
shadinrahman's Avatar
Member: 1872223
Sonork: 100.1671449:33635978
Thanks Meter: 25
ipad 2 3g+wifi error -1
Old 08-08-2016, 12:02   #55 (permalink)
Member: 1703068
Sonork: purna33
Thanks Meter: 5
Thumbs up solve
chnage original battery 100% solved
Old 08-11-2016, 12:49   #56 (permalink)
Member: 1033148
Sonork: 100.1622890
Thanks Meter: 8
Fainaly done change battery
Old 08-12-2016, 12:17   #57 (permalink)
Member: 2536693
battery problem change the battery and make
restore
Old 09-28-2016, 13:39   #58 (permalink)
Member: 2606474
i phone 4s error 29
first check bettery
second check charging flex
third check camera and other flex
just unplug them and put them back
try now
100% done
Old 10-03-2016, 02:23   #59 (permalink)
Member: 2486096
check battery connects ways and battery
Old 10-08-2016, 19:16   #60 (permalink)
Member: 1487405
Thanks Meter: 31
change the battery and the problem solved error 29 with 2 iPhone
The Following User Says Thank You to malike9999 For This Useful Post:
Page generated in 0.32204 seconds with 7 queries
