Old 10-15-2013, 13:24   #1 (permalink)
talhagsm143's Avatar
Member: 1243555
Thanks Meter: 664
iTunes v11.1 Custom IPSW Restore Error-11 Fix
A few days ago I was trying to restore an iPhone 4 using a Custom IPSW and I was presented with a nice iTunes Error 11 like the one posted above. I had a feeling that this was something to do with iTunes v11.1. So I downgraded back to iTunes v11.0.5.5 and all was well. However since a couple weeks have passed since I'd installed iTunes v11.1 I didn't want to completely redo my library nor did I want to waste time reverting to a previous iTunes Library file since it wouldn't be current anyways.
After doing some research I found this on the iH8sn0w blog...
Originally Posted by iH8sn0w
iTunes 11.1 - WHAT IS THIS?! GO AWAY?!
Along with Apple pushing iOS 7, they updated iTunes to 11.1. This actually brought more headaches than convenience.
When a user hits the restore button, they often see "iTunes will erase and restore your iDevice to iOS x.x.x and will verify the restore with Apple". What this does is submit a request to Apple for an apticket + SHSH blobs. Previous revisions of the iTunes Mobile Device Library would just use the BuildManifest included inside of an IPSW to supply the request to Apple with the essential "hashes" of each image within the IPSW. When tools like sn0wbreeze, PwnageTool, seas0npass, or redsn0w modified images such as iBSS, iBEC, ramdisk to avoid signature checks during the restore, iTunes didn't care or know.
Now, prior to iTunes sending the TSS request to Apple, they ignore the values already in the BuildManifest and "re-hash" every image within the IPSW to create the TSS request. Meaning if 1 byte of any image is modified, when iTunes calculates the new "hash" and sends the TSS request, the TSS server will refuse to fulfill the request (Error 3194 is displayed). This essentially kills iOS 7 custom IPSW restores via iTunes.
Moving on to Error 11... This error seems to only be related to devices with basebands that require bbtickets (So basically the iPhone 4). Even though iFaith/sn0wbreeze removes the baseband requirement, iTunes 11.1 is expecting the iPhone 4 baseband firmware to be signed no matter what and notices that it isn't. This causes it to error out with code 11 (Error 11). It is worth noting that this issue was already present in the Mac OS MobileDevice framework on iTunes 11.0.x. When iTunes 11.1 was released for Windows, it looks like they finally merged code. Thus bringing the issue to Windows with iTunes 11.1. This does not affect the iPhone 3GS (bbfw is always pre-signed),
A temporary workaround to fixing Error 11 on Windows is by downgrading to iTunes 11.0.x. You can find download links to old revisions of iTunes over here (thanks cj!).
One more thing worth mentioning is iREB for the iPhone 2G, iPhone 3G, and iPod touch 1G is broken with the iTunes 11.1 update. This is on my list of things to fix, but again... a workaround is typed up above.
I know most people like myself have already updated to iTunes 11.1.x.x and would rather not be burdened with having to downgrade and have to redo their entire library. Well never fear, I is here
I've created a "FIX" for the issue which will replace the problematic files with files from iTunes v11.0.5.5 and will allow you to restore Custom IPSW's to your device using iTunes 11.1.x.x without getting Error 11 messages.
This fix was tested on iTunes v11.1.1.11 but will more than likely work with any newer versions of iTunes until of course Crapple changes something else. If you install this fix and it doesn't work for you then you can simply uninstall the fix and it will revert iTunes back to it's original state. So there is no harm in testing it with newer versions of iTunes.
This fix only needs to be applied to iTunes version greater than v11.1.0.0. The last good version of iTunes that doesn't have the "Error-11" issue is v11.0.5.5. You can either downgrade to iTunes v11.0.5.5 or simply apply this fix to your iTunes v11.1.x.x or higher to resolve the issue.
This fix works with both 32-bit and 64-bit versions of iTunes.
Simply download and extract the ZIP file in the link below and run the included EXE file. It's very straight forward and more info is included once you launch the FIX.
iTunes_v11.1_Error-11_Fix_v1.3.zip
Version: 1.3
MD5: ebe0b47500d719b19c9169b6259db6e6
Changelog
v1.3
- Added a check for Administrator Priviliges
v1.2
- Fix for iTunesHelper.exe not restarting on 64-bit OS's
v1.1
- Fix for iTunesHelper.exe not restarting on 32-bit OS's
v1.0
- Initial Release
The Following 21 Users Say Thank You to talhagsm143 For This Useful Post:
Old 10-16-2013, 04:41   #2 (permalink)
Crazy Poster
Member: 667151
Thanks Meter: 5
usefull post but your text gives me a head ache
The Following User Says Thank You to princess_6600 For This Useful Post:
Old 10-18-2013, 07:09   #3 (permalink)
Member: 1243555
Thanks Meter: 664
ohhh really bro ?????????
The Following 2 Users Say Thank You to talhagsm143 For This Useful Post:
Old 10-21-2013, 07:10   #4 (permalink)
Member: 412812
Thanks Meter: 97
THANKS but not working your solution for me same 11 error....
Old 10-21-2013, 07:17   #5 (permalink)
Member: 1243555
Thanks Meter: 664
bro i m tested 1000% working
if not work add me on yahoo i will help u via TeamViewer
The Following User Says Thank You to talhagsm143 For This Useful Post:
Old 10-21-2013, 11:04   #6 (permalink)
Member: 336175
Thanks Meter: 8
i am tested 1000% working ... thanks man...
The Following User Says Thank You to why not bar For This Useful Post:
Old 10-21-2013, 16:27   #7 (permalink)
mimo.gsm's Avatar
Member: 1833931
Sonork: 100.1614948
Thanks Meter: 38
thanks
The Following User Says Thank You to mimo.gsm For This Useful Post:
Old 10-21-2013, 17:32   #8 (permalink)
Member: 2012075
Thank you for your guide.
Didn't work for me though, iPhone hangs on Apple logo. Will try on laptop tomorrow
Old 10-22-2013, 07:52   #9 (permalink)
Member: 1243555
Thanks Meter: 664
Old 10-26-2013, 09:23   #10 (permalink)
Member: 1497696
Thanks Meter: 9
i am also tested 1000% working .
Old 10-26-2013, 11:58   #11 (permalink)
cobra iphoni's Avatar
Member: 1744389
Sonork: 100.1657056
Thanks Meter: 218
Working like a charm bro..few days from now, win 7 64bit
Thanked also patch maker..
Its easy to downgrade itunes to 11.0.5, but i dont wanna deal with 2-3 PC, when i have my personal one for daily job..
with this fix, you can restore and ios 7.x.x and syncro idevices, and downgrade to any lower firmware, custom one with ssh....all in one
Old 10-26-2013, 17:25   #12 (permalink)
Member: 2053811
Thank you very much it works well Thank you
Old 10-29-2013, 13:52   #13 (permalink)
Member: 739410
Thanks Meter: 88
from latest itunes this fix not working
Old 11-01-2013, 15:49   #14 (permalink)
Member: 2057547
Man i did what u say and it didn't works :/
i try to downgrade my iphone 4 from ios 7.0.3 to ios 6.0.1 or 6.1.2 and alot 6.x.x
please could you help me via team viewer ??
Old 11-04-2013, 23:56   #15 (permalink)
Member: 784101
Sonork: 92737
Thanks Meter: 9
yu are great thanks bror keek it up
Page generated in 0.45063 seconds with 8 queries
