Old 10-15-2011, 17:17   #1 (permalink)
Member: 818647
Sonork: christyjohn
Thanks Meter: 12
Thumbs up Jailbreak iOS 5 GM On iPhone, iPod Touch And iPad 1 Using Redsn0w 0.9.9B2
Apple seeded iOS 5 GM (final version) an hour ago and it has been jailbroken. You can now jailbreak iOS 5 GM using redsn0w 0.9.9b2, the catch is you have to point redsn0w to iOS 5 beta 7 IPSW in order to make it work. This jailbreak is tethered for now which means you will have to boot in tethered mode and jailbroken state every time you reboot your iOS device.
An updated version of redsn0w, redsn0w 0.9.9b3 is expected shortly which will support iOS 5 GM jailbreak directly which means you won’t be pointing it to iOS 5 beta 7 IPSW file. If you just can wait to get you device jailbroken you can download redsn0w 0.9.9b2 from the link below and jailbreak iOS 5 GM right away.
Redsn0w got upgraded recently and has become an All-In-One jailbreaking tool. following new features were added in this mighty upgrade :
  • uses DFU mode to try to automatically determine which device and FW you have
  • fetches pieces of public IPSWs from Apple (once). Non-public IPSWs must be provided manually (once). It then caches those pieces for future use.
  • “Just boot” is a tethered boot. Uses whatever “Preferences” you’ve set for boot logo and kernel boot-args
  • “Pwned DFU” puts your device in a pwned DFU state for some of the iTunes stuff detailed below
  • “Recovery fix” gets past 1015 types of errors (when baseband portion of restore fails). Should work on iOS5 beta too
  • “Select IPSW” is for picking non-public IPSWs, or overriding auto-detection
  • “SHSH blobs” has a bunch of options…
  • “Fetch” – fetch current PARTIAL blobs on device. Should complete in under 10 or 15 seconds. Puts the set of PARTIAL of blobs on your computer as a plist. Checks if Cydia already has a full set for this device and build. If not, it submits this PARTIAL set and returns Cydia’s acknowledgement or rejection
  • “Verify” – cryptographically verifies existing blob files from either redsn0w, TinyUmbrella, or Cydia server. You can select a whole bunch of blobs to verify at once if you want (like the TinyUmbrella directory)
  • “Submit” – both verifies and submits one or more blob files to Cydia. This lets you copy your entire TinyUmbrella cache of blobs up to the Cydia server
  • “Query” - queries the Cydia server for all available FULL or PARTIAL blobs for a given set of ECIDs
  • “Stitch” – stitches either FULL or PARTIAL blobs to a STOCK or CUSTOM IPSW
  1. Stitching is NOT yet supported on iPhones! Need to work out the baseband part of the restore process.
  2. FULL blobs stitched to a STOCK IPSW gives you a completely self-contained signed IPSW that iTunes will accept without any tricks (no need to go into pwned DFU mode, no need to start TinyUmbrella TSS server, no need to redirect to Cydia server for blobs)
  3. PARTIAL blobs stitched to any IPSW requires you to go into pwned DFU mode before running iTunes. No need to start TU or use Cydia though.
  4. Stitching either FULL or PARTIAL blobs to a CUSTOM IPSW also requires a pwned DFU start before iTunes restores. No need to start TU or use Cydia though.
  5. Will eventually support fetching the blobs directly from Cydia instead of a file on your computer
Download redsn0w 0.9.9b2
The Following User Says Thank You to christyjohn2009 For This Useful Post:
Old 10-15-2011, 18:17   #2 (permalink)
Member: 997558
Thanks Meter: 20
Why do you write?
It's outdated Redsnow!
It has long been out redsnow 0.9.9b5 for mac, and for windows 0.9.9b4
Here are instructions on how to make Jailbreak
The Following User Says Thank You to romadim For This Useful Post:
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.13534 seconds with 9 queries
