Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 10-10-2010, 00:04   #1 (permalink)
Techgsmnet's Avatar
Member: 499855
Thanks Meter: 397
Jailbreak iPhone 4, 3GS on iOS 4.1 with Limera1n Step by step!!!
Moments ago, we posted that Limera1n was released to jailbreak all iOS 4.1
devices forever. We promised with how-to guides and here we go, you can now use the step by step guide below to jailbreak iPhone 4 and iPhone 3GS using Limera1n on Windows only.
Here's the instructions to jailbreak iPhone 4, 3GS on iOS 4.1 using Limera1n, PLEASE read the important notes at the end of the post:
STEP 1: Download Limera1n for Windows from here.
STEP 2: Connect your iPhone to your PC via USB then launch Limera1n and hit “make it ra1n”
STEP 3: You will have to get your device into DFU mode by following the steps on the screen shown by Limera1n.
  • You iPhone will now be placed in recovery mode.
  • Press both the power and the home buttons.
  • When Limera1n asks you to, release the power button.
  • Your phone will now be in DFU mode
STEP 4: Now, Limera1n app should be shown on your iPhone's home screen. Limera1n will pwn your device forever now.
STEP 5: The jailbreak should be done now. Tap on the limera1n icon on your device and install Cydia.
IMPORTANT:
You have to keep some points in your mind, first, Limera1n will not unlock your device (i.e. you will lose unlock if you upgraded to iOS 4.1 and used limera1n).
Second, Limera1n is not working with old bootrom devices and it doesn't support iOS 4.2 beta, Geohot is fixing the issues right now. Stay tuned.
Limera1n would mess up GreenPois0n jailbreak release as the teams don't want to give Apple two exploits. They would better save one of them to 5th-generation devices.
Regards
Techgsmnet
Last edited by DrMobile; 10-10-2010 at 15:06. Reason: links changed to correct one,
The Following 370 Users Say Thank You to Techgsmnet For This Useful Post:
Old 10-10-2010, 00:20   #2 (permalink)
Member: 682988
Thanks Meter: 45
Thank you,
Anyone have modified firmware for IPhone 4 4.1 to avoid upgrading baseband ?
The Following 3 Users Say Thank You to dogeatdog For This Useful Post:
Old 10-10-2010, 00:25   #3 (permalink)
cobra02a's Avatar
Member: 175671
Thanks Meter: 40
yes , finally it's work , i tested it on iphone 4G version 4.0.2
thanks geohot
The Following User Says Thank You to cobra02a For This Useful Post:
Old 10-10-2010, 00:28   #4 (permalink)
Member: 463420
Thanks Meter: 150
jailbreak is easy solution, the big question is when will be done solution for unlock of new modem version
The Following User Says Thank You to chimeto For This Useful Post:
Old 10-10-2010, 00:28   #5 (permalink)
quickgsm's Avatar
Member: 414755
Sonork: quickgsm
Thanks Meter: 389
good news !!!!!!!!!!!!!!!!!!!!!!!!
BR / TA@UFIK
BY / QUICK - MOBILE
The Following User Says Thank You to quickgsm For This Useful Post:
Old 10-10-2010, 00:28   #6 (permalink)
Member: 14149
GeoHot wrote:
known bugs
3GS new bootrom is broken, fix pending
Old 10-10-2010, 00:32   #7 (permalink)
Member: 463420
Thanks Meter: 150
It work bro, try again and post result!
Old 10-10-2010, 00:32   #8 (permalink)
Member: 1121044
Thanks Meter: 48
Very good unlock iphone 4g 4.02 very good unlock 100% working
The Following 2 Users Say Thank You to LokitoFlasheo For This Useful Post:
Old 10-10-2010, 00:38   #9 (permalink)
simplex's Avatar
Member: 59797
Thanks Meter: 76
And what about unlock?
Ultrasn0w is supported on v. 4.1 or not???
Please give a clear answer.
Thx
Old 10-10-2010, 00:53   #10 (permalink)
Member: 1223400
it's my problem soooooo
Old 10-10-2010, 01:03   #11 (permalink)
Member: 682988
Thanks Meter: 45
Originally Posted by dogeatdog View Post
Thank you,
There's no modified firmware as in the past with the 3Gs to update to 3.1.3 and keep 05.11.07....
I find this method on iclarified iClarified - iPhone - How to Update Your iPhone 4 Without Upgrading the Baseband (Windows)
only for IPHONE 4, to update to 4.1 and keep the baseband on 01.59.00, to be able to unlock it after...
I hope that it will work for Iphone with the apple logo freezing on the startup!?
The Following 4 Users Say Thank You to dogeatdog For This Useful Post:
Old 10-10-2010, 01:14   #12 (permalink)
Member: 73934
Thanks Meter: 4
tested iPad 3.2.2 works perfectly
Old 10-10-2010, 01:19   #13 (permalink)
Member: 936896
Thanks Meter: 14
can you be more clear about the unlock?
i mean if you have firmare 4.1or 4.2 on iphone 3gs,once u jailbreak the phone with limera1n,is it possible to unlock it ?
The Following User Says Thank You to cpu2007 For This Useful Post:
Old 10-10-2010, 01:21   #14 (permalink)
darksman's Avatar
Member: 849979
Sonork: 100.1603463
Thanks Meter: 923
its simple no unlock until further notice
br
Old 10-10-2010, 01:35   #15 (permalink)
Member: 644210
Thanks Meter: 74
does it support 4.02 fw 3gs???
The Following 2 Users Say Thank You to ogie98 For This Useful Post:
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.25463 seconds with 9 queries
