Old 03-10-2014, 12:35   #1 (permalink)
unlock & flash's Avatar
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
no icloud id inside ,but still need apple id
hello
i am just received iphone 4 ,which is active iphone but without network ,then i am connect to this phone in itunes but need apple id for active this phone .then i am check in this phone no icloud id inside ,fully active without any apple id ,and i am setup myself apple id in this phone and find my iphone option on then connect again on itunes for active ,but dont accept my apple id ,but in phone in side my apple id accepted .
ok below i am uploading some screenshot ,pls someone help me how can i active this phone
Old 03-10-2014, 14:06   #2 (permalink)
Member: 226967
Thanks Meter: 47
its a stolen phone
phone lost and erased
you need to restore device to last ios 7.0.6 then activate with icloud id the owner not yours
or remove it from icloud.com
this phone working with no network because of setup.app is deleted but still not activated
for more information contact me
The Following User Says Thank You to sid-ahmed For This Useful Post:
Old 03-10-2014, 14:12   #3 (permalink)
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
Originally Posted by sid-ahmed View Post
its a stolen phone
yes i know about that ,but if i can know the used apple id on this phone i can just use previous owner apple id and phone have to active
my question ,if i dont know previous owner apple account how i can remove old id from i cloud ?
reply me
Old 03-10-2014, 14:14   #4 (permalink)
Cheater -Don't Deal with him-
Member: 2399
Thanks Meter: 747
Originally Posted by unlock & flash View Post
hello
bro imei post ??????
Old 03-10-2014, 14:22   #5 (permalink)
Member: 226967
Thanks Meter: 47
you have itunes backup?
Old 03-10-2014, 16:11   #6 (permalink)
Member: 1360950
Thanks Meter: 78
Before restoring ID was activated and someone removed ID by tricky procedure but originally it is activated on server. So there no solution to bypass this ID.
Old 03-10-2014, 20:07   #7 (permalink)
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
Ok ,will be happy if u do something for me to solved this issue
Imei -012651002465116
Old 03-10-2014, 20:21   #8 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
See Here.
IMEI: 012651002465116
Serial Number: 88115Y8CDZZ
Activated: Yes
Find My iPhone: On
Last Activated SIM: Bouygues - France FRA
Telephone Technical Support: Expired
Repairs & Service Coverage: Expired
Contract: Expired
Carrier: Unlock
SIM Lock: Unlocked
Unlocked But Find Iphone Is On It's Mean This Device Already Add In Icloud Account.Do Not Restore It's Totally Locked iCloud...
WBR.
Arsalan gsm2000.
Old 03-11-2014, 04:18   #9 (permalink)
Member: 1318873
Thanks Meter: 18
hello
Go to gadgetwide .com witout espace and see tutorial how to replace à specified files with other you may download a folder with all you need
Old 03-11-2014, 06:05   #10 (permalink)
saydajan's Avatar
Member: 1318893
Sonork: 100.1640487
Thanks Meter: 279
just log on with ur own id then u can restor it and activate easly.
Old 03-11-2014, 08:15   #11 (permalink)
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
are u sure bro ,after use my own apple id and then restore i can active this phone used my own id ,pls make sure cause this phone is active now ,but after restore if not works with my own id then i cant used this phone as a ipod also .so pls make sure again
waiting for your answer
Old 03-11-2014, 08:19   #12 (permalink)
saydajan's Avatar
Member: 1318893
Sonork: 100.1640487
Thanks Meter: 279
yes bro when you logon ur id then it will be ur phone bcs the prevous will be replace with ur id.
Old 03-11-2014, 08:21   #13 (permalink)
saydajan's Avatar
Member: 1318893
Sonork: 100.1640487
Thanks Meter: 279
or just logon wih ur id and then remove ur id from it then try to check find my iphone on web sites or servers then see is it off or not.
Old 03-11-2014, 08:35   #14 (permalink)
Member: 226967
Thanks Meter: 47
you can try to restore nothing to lost (i think doesnt work)
dont try ios7.1 you can try same ios by tinyumbrella shsh server method
then hackactivate by smolk soft (easy & can sync w itunes & jailbreak)
Old 03-11-2014, 09:47   #15 (permalink)
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
can i restore this phone under os 7.0 ?
Page generated in 0.21306 seconds with 9 queries
