09-26-2012, 10:43 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Location: Nigeria,Kano Age: 55
Member: 171281 Status: Offline Thanks Meter: 26 | pls help restore iphone4 to ios 5.1.1 pls can someone guide me on how tyo go about it, i dont want to update to ios 6.0 thanks in advance |
09-26-2012, 12:46 | #2 (permalink) | |
Freak Poster Join Date: Sep 2012 Location: india Age: 35
Member: 1810080 Status: Offline Thanks Meter: 51 | Quote:
09-26-2012, 12:56 | #3 (permalink) | |
Member: 171281 Status: Offline Thanks Meter: 26 | Quote:
thanks | |
09-26-2012, 13:58 | #5 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 48396 Status: Offline Thanks Meter: 82 | You can't restore to iOS 5.1.1 without saved SHSH blobs. Make custom firmware, signed with your saved SHSH. Enter phone to pwned dfu, restore with your custom fw. Last edited by UnReality; 09-26-2012 at 14:06. |
The Following User Says Thank You to UnReality For This Useful Post: |
09-26-2012, 14:46 | #6 (permalink) | |
help pls for i dont want to go back to ios 4.1. thanks | |
09-26-2012, 15:14 | #7 (permalink) |
Member: 48396 Status: Offline Thanks Meter: 82 | I've just did it used redsn0w_win_0.9.14b2. My step by step instruction: 1. Download stock iPhone3,1_5.1.1_9B208_Restore.ipsw fw (fw for which you have saved SHSH). 2. Run redsn0w, press "Extras -> SHSH blobs -> Stitch". 3. Press "IPSW", select stock fw. 4. Press "Local" if you have locally saved SHSH blobs and select for your fw version, press "Cydia" to use SHSH saved on server (phone must be connected to PC via usb cable). Your custom fw will be saved in same dir where is your stock fw with name starting with your phone's ECID. 5. Go back to start screen, press "Extras -> Pwned DFU", follow instructions. 6. When you get your phone to Pwned DFU mode start iTunes. 7. Press restore holding shift, select your just created custom signed fw, wait for process to end. 8. Your phone will reboot in recovery mode. 9. Run redsn0w, press "Extras -> Recovery fix", follow instructions. 10. After process finish, your phone will start normally and ask for activation. Don't use any usb hubs, better connect your phone to rear panel's usb port. BR |
The Following 5 Users Say Thank You to UnReality For This Useful Post: |
09-26-2012, 17:46 | #8 (permalink) | |
THANKS SO MUCH. | |
