02-05-2016, 03:33 | #1 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2526901 Status: Offline Thanks Meter: 0 | Power Button fastening screw holes stripped I got a replacement power button and in the process of putting it into the phone found that one of the two screw holes holding the power button housing was stripped (not the screws they were fine). Any suggestions on what to do about this? I was thinking I might glue it. |
02-05-2016, 12:03 | #2 (permalink) | |
Junior Member Join Date: Jan 2016 Location: Moscow
Member: 2510154 Status: Offline Thanks Meter: 2 | Quote:
you can buy a middle frame (about $5) and replace it completely. use google to find good-illustrated replacement guide and be carefull with srews)) | |
The Following User Says Thank You to KotNitro For This Useful Post: |
02-09-2016, 00:17 | #3 (permalink) |
Member: 2526901 Status: Offline Thanks Meter: 0 | Hi thanks for the advice. I ordered a middle frame, but noticed when I got it says it is only for GSM iPhone 4, I have a Verizon CDMA phone. I can't seem to find Iphone 4 CDMA middle frames are they the same as Iphone 4s middle frames, a few sellers seem to think so? |
02-12-2016, 08:52 | #4 (permalink) |
Member: 2510154 Status: Offline Thanks Meter: 2 | iPhone 4 and 4S midframes are not the same, please check I'm sure you can easily order a middle frame for iPhone 4 CDMA from Chinese sellers, from AliEpress, for example. |
