08-05-2010, 18:56 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Age: 37
Member: 161823 Status: Offline Thanks Meter: 71 | Problem: i'm activating iphone 3GS4.0.1+3G with activate simcard -------------------------------------------------------------------------------- when i activate with activating sim card and i;m using spirit for jailbreak and cydia was installed on iphone. but when i put another sim card , again show me emergeny cablle: any solution br denny86 |
08-07-2010, 04:27 | #4 (permalink) |
Freak Poster Join Date: Jun 2003 Location: Dosunlock Age: 38
Member: 31942 Status: Offline Thanks Meter: 42 | * for 3g and 3gs unit's activated by onesim. for version 3.1.2 to 4.0.1 1. put onesim inside unit. dont remove until the instruction says so. 2. restore a firmware version you like via itunes. 3.after restore. just keep the unit plug in and wait for it to boot and let itunes detect it and activate it. 4. after activation, set the iphone as a new iphone, then make the name of the unit to iPhone. 5. let it finish syncing, after syncing, uncheck open itunes when this iphone is connected. 6. remove iphone from cable, go to settings , general , autolock and set it to never. 7. connect to wifi and jailbreak using jailbreakm.com via safari. 8. after jailbreak let cydia update essential and do a complete upgrade when promted. 9. now search and install open ssh, automaticssh and ultrasnow. after install reboot. 10. download my version of my edited lockdown files and extract to desktop. new_Lockdownfix.rar - 4shared.com - online file sharing and storage - download * (my edited version of the data_ark.plist resolves the problem of iphone when unplug the pc will detect that you are plugging a device and itunes cannot detect the iphone because of a invalid response.) 11. now ssh to your iphone using winscp, navigate to /private/var/root/Library/Lockdown folder 12. on the lock down folder of iphone delete all the files inside. 13. now navigate to your desktop and open lockdown folder thru winscp, copy the 3 files from desktop lockdown to the iphone lockdown folder. *( steps 11 to 13 can be done also using ifunbox but sometimes it will not work, its better to use winscp) 14. now reboot you iphone, and wait for it to boot up until you can see the spring board. remove now onesim and put in another sim. wait for it to catch a signal. 15. after signal has been establish. connect now your iphone to itunes. if it can detect it sync one more time. and your done. *( if you have error which is cannot connect due to invalid response. remove cable from iphone, shh to your iphone using winscp navigate to /private/var/root/Library/Lockdown and delete the folder pair_records and connect to itunes again. this time it will detect and sync one more time.) B.R. Dennis2003 |
The Following User Says Thank You to dennis2003 For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
