10-11-2012, 13:57 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: UK
Member: 1779384 Status: Offline Thanks Meter: 13 | problem with iphone 4 after screen replacement After screen replacement the iphone will not read any sim card correctly, if i insert a sim with the phone already powered on it does not reconise the sim being inserted, but if i insert the sim with it powered off then start it up it will see the sim card, but if i eject the sim card it still says the sim card is inserted. with the sim inserted from power off, once it starts up if i try to make a call it will not actually ring out, it just says calling, and if i try to end the call it just says ending and will not move on from there, i have to reboot the phone. ive had this problem a few times with screens ive replaced but it usually just goes away and fixes itself some how, but this time it wont. has anyone else had this problem and if so how did you fix it. many thanks for any help anyone can provide, regards, clive |
10-11-2012, 14:36 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Sri Lanka@cellularsolutions
Member: 230004 Status: Offline Thanks Meter: 174 | I can't exactly tell you where the problem lies.. But I've been changing original lcds never faced a problem like that. Probably you got a faulty lcd.*try to restore *try to check the power consumption with both lcds original one and the replaced one. * try to fix an original lcd set and see * check the sim socket * |
10-11-2012, 16:40 | #3 (permalink) |
Member: 1779384 Status: Offline Thanks Meter: 13 | tried an original lcd and aftermarket ones but no change. sim socket is fine, im using an original micro sim not a cut down one. even tried it with the logic board removed from the housing but still no change. it really is strange, only thing ive not tried is a reinstall as yet. I do this for a living part time (as im a house husband now, but i used to work for alps elctronics) so im not exactly a newbie at this lol. but this problem is really bugging me now. |
01-12-2013, 18:33 | #6 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Amman, J o r d a n. Age: 43
Member: 1529244 Status: Offline Sonork: 1720 Thanks Meter: 150 | Brother, First: try to restore 6.0.1 with itune and then check if you see the problem is same problem. Second : replace original Lcd. |
01-12-2013, 19:55 | #7 (permalink) |
Junior Member Join Date: Apr 2008 Location: banglour Age: 54
Member: 749979 Status: Offline Thanks Meter: 5 | in many phone with ver 6.0.1 if we change the lcd many pro will come may be some bugs after change display can't call hang on calling screen every thing is right sencor not working no tention restore again all pro. will solve i done in many sets............. |
01-12-2013, 20:50 | #8 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Romania Age: 48
Member: 59869 Status: Offline Thanks Meter: 132 | Common problem with IOS 6.x.x when disconnecting the battery. Just set manually the DATE and time and restart the phone. Being discussed many time already. |
01-13-2013, 01:09 | #9 (permalink) |
No Life Poster Join Date: Apr 2009 Location: lebanon Age: 37
Member: 1008455 Status: Offline Sonork: 0000 Thanks Meter: 99 | first connect to a wifi or simcard internet to acsses network go to setting and update ur date and time if not worked go to language and change it to diffrent ex to ( arabic ) then change it back to ( english ) it will work last chance update ur ios to last version |
01-13-2013, 02:00 | #10 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Opensource
Member: 903254 Status: Offline Sonork: 100.1592789 Thanks Meter: 86 | Happened to me almost everytime i changed the touchscreen+display. Just restore it to the version the iphone is on (via iTunes) and activate it with the original sim card (if it`s locked) or any other (if it`s not). Make a backup of the contacts and others (apps, pics). Then you should be set. |
