12-22-2014, 22:59 | #1 (permalink) |
Crazy Poster Join Date: Dec 2013 Location: TUNISIA Age: 33
Member: 2083000 Status: Offline Sonork: 100.1653938 Thanks Meter: 7 | READ PassCode on iPhone 4 iOS 7.1.2 help !! |
12-22-2014, 23:21 | #2 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | READ PassCode on iPhone 4 iOS 7.1.2 help !! well, open file run.bat and see if the filename ipsw is 3,1 not 2,1 and , try change usb ports if wont work try other pc , also try to this trick when you put in dfu and lunch redsn0w hold again home button Best Regards,Besfort |
The Following User Says Thank You to BesfortShalaTec For This Useful Post: |
12-23-2014, 01:43 | #3 (permalink) |
Member: 2083000 Status: Offline Sonork: 100.1653938 Thanks Meter: 7 | yes my ipsw is 3.1 end i try with other pc xp end 7 other cable dfu ---> end open redsn0w pawn dfu not fix :/ but i hold to home button is done but enter to recovery mode :/ :/ |
12-23-2014, 20:56 | #4 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2200933 Status: Offline Thanks Meter: 0 | make sure iPhone is model 3,1 and not model 3,3. I have ran into this problem as well. No solution found as of yet. You can however edit the batch file to support the 3,3 ipsw, but I have yet to get the password removed from the device. |
