Old 03-31-2013, 21:02   #1 (permalink)
Member: 182134
Thanks Meter: 16
iphone 4s hang when make calls not end call
iphone 4s not end the call also stop at call making screen when i press home button it come back home screen and again when i on call function its still show hang call screen whats the reason .
Old 03-31-2013, 21:07   #2 (permalink)
shedeed's Avatar
Member: 527884
Sonork: 100.1583794
Thanks Meter: 850
Just Restore It To 6.1.3 Iphone Will Be Fine
Regards
Old 03-31-2013, 21:32   #3 (permalink)
Member: 1628342
Sonork: 1592100
Thanks Meter: 38
hello pls can u tell what was the cause incase u are the one who use it or if customer then asked may can help to solve the problem just incase restore does not solve the problem. pls note must be factory unlock b4 u restore if not possile gavey may not work after restore
The Following User Says Thank You to segnattech For This Useful Post:
Old 03-31-2013, 22:03   #4 (permalink)
Member: 1882458
Sonork: 100.1624780
Thanks Meter: 34
bro just change lcd panel and ur problem solve
Old 04-01-2013, 08:00   #5 (permalink)
Member: 1709244
Sonork: gsmnasir
Thanks Meter: 45
Hi Bro....
Don't worry u want to do
1: first make on airplane mode
2: then make correct date & time by manually
3: make off airplane mode
4: also you should delete phone icon from minimize (when u double click home button)
and check it now...
::gsmnasir::
The Following User Says Thank You to gsmnasir For This Useful Post:
Old 04-01-2013, 08:11   #6 (permalink)
Member: 34379
Thanks Meter: 101
Activate phone with other network sim card, after that put back your sim card
Old 04-01-2013, 08:15   #7 (permalink)
dubai@mobile's Avatar
Member: 1711454
Sonork: 100.1605681
Thanks Meter: 60
brother
1st==check if u have 6.1.2
then just jailbreak problam solve insha allah
The Following User Says Thank You to dubai@mobile For This Useful Post:
Old 04-01-2013, 16:29   #8 (permalink)
Member: 182134
Thanks Meter: 16
airplan mode not work / jailbreak not work going to change LCD
Old 04-01-2013, 19:38   #9 (permalink)
Member: 182134
Thanks Meter: 16
LCD change also not work.
Old 04-01-2013, 19:57   #10 (permalink)
Member: 182134
Thanks Meter: 16
when i remove charging base connector and make call its conect to network but no sound in earpease and loadspeaker and END call not function same hang on end call screen.
Old 04-02-2013, 09:47   #11 (permalink)
Member: 1557216
Sonork: 100.1625551
Thanks Meter: 4
use the tinyumbrella litest ver.. 1st enter recovery ..2nd exit recovery your problam 100% sold..
The Following User Says Thank You to murad hasrat For This Useful Post:
Old 04-02-2013, 11:47   #12 (permalink)
Member: 1349302
Thanks Meter: 4
just set date and time proper it will work
Old 04-02-2013, 15:32   #13 (permalink)
Member: 182134
Thanks Meter: 16
problem solve exit recovery work.
Old 04-02-2013, 16:57   #14 (permalink)
irfan_gsm's Avatar
Member: 709520
Thanks Meter: 275
exit recovery???? can you explain more plssss
Old 04-02-2013, 20:59   #15 (permalink)
Member: 182134
Thanks Meter: 16
problem come back again after some time and exit recovery not work now.
Page generated in 0.19885 seconds with 8 queries
