GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   iPhone 4 / iPhone 4S (https://forum.gsmhosting.com/vbb/f456/)
-   -   Restore 3gs without SHSH (https://forum.gsmhosting.com/vbb/f456/restore-3gs-without-shsh-1158833/)
RarePearl 12-08-2010 06:30
Hi to all..
Today i have figure out a way to flash a 3gs without cydia saved shsh.
I had one 3gs (3.1.3) with sec code. no cydia was saved. but i did a try but not work.
The method worked for me :
Put the phone in recovery mode.
Get the ECID with usbview.exe
start tiny umbrala and select the manual ECID
put the name of the device..past the ECID and select the 3gs and click on "create custome device"
open redsn0w_win_0.9.6b5 and select orginal fimware 4.1 and proceed..and select "yes" and than "just enter in pwned dfu mode right now"
let it fininhed.
run the tiny umberala and start tss server.
and restore the firmware 4.1 with shift key
when finished.. activate and unlock.
Worked for me... Maybe help full for some one else also.
Thanks
ps. sorry for my bad english.
peter0206 12-08-2010 06:49
thanks for sharing, would it works for 4.2.1 downgrade to 4.1 please?
waitting for the test.... and for the ECID part, is it Dec or Hex please?
Thanks
hariskt 12-08-2010 06:59
Thanks
it wont work..........dear....you will get error....
Amir-SkillZ 12-08-2010 08:03
Thanks
U put manually the DEC converts to HEX auto.
RarePearl 12-08-2010 08:27
Yes.. just copy and past like this:
ECID:00000247BA057D2E IBFL:01 SRNM:[87949U3M3NQ] IMEI:[012029005152652]
00000247BA057D2E is your ECID copy it and past it in the tiny umbrella
kevin168 12-09-2010 22:59
i've been success following your tutorial.
this is a working solution, just note i need to use redsn0w_win_0.9.6b6 as the b5 version
unable to recognize ipsw :D
br,
kevin168
Accessvaasu 12-10-2010 04:09
Tks Bro 10000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 0000000000000000% Worked
EL LOCO MEXICAN 12-10-2010 08:39
Originally Posted by RarePearl (Post 6663780)
Hi to all..
let it fininhed.
Thanks
Will this downgrade my base band ?
And how can you unluck 4.1 with out updating your baseband to an I pad?
uzair007 12-14-2010 10:09
after restore 3gs stuck on dfu
MUNEEB_AKHTAR_RAZA 12-14-2010 12:21
Just booot thehtered right now in redsnow........;)
yadra^^ 12-14-2010 13:14
thank for sharing but please explain how to get Ecid by usbview.exe
i enter recovery mode but i can't see Ecid .
deep24 12-14-2010 13:21
brother you have any video the hole procss?
blackr41n 12-14-2010 15:36
wierd.. no need usbview, with tinyumbrella u can see ECID & i think this is will not work
Page generated in 0.15043 seconds with 6 queries
