10-28-2012, 04:47 | #1 (permalink) |
No Life Poster Join Date: Nov 2011
Member: 1696653 Status: Offline Sonork: 100.1638410 Thanks Meter: 809 | restore ios 5 prfect solution
If you fulfill the above mentioned requirements, then you can proceed to the below mentioned tutorial for restoring your iPhone. Step 1: Create a folder on your Windows computer and rename it to “Jailbreak” Step 2: Download the latest RedSn0w which can be found and place it in the “Jailbreak” folder you created in the first step. Step 3: Download the firmware you’d like to restore to and also download the firmware you are currently on from here and place them in the “Jailbreak” folder. Step 4: Extract the RedSn0w zip file to the “Jailbreak” folder. Step 5: Now go in the RedSn0w folder inside the “Jailbreak” folder and then right click on the RedSn0w application and choose “Run as Administrator” from the popup that appears. Step 6: Click on “Extras” in the RedSn0w app that will open up. Step 7: Click “Even More”. Step 8: Click on “Restore”. Step 9: Click on “IPSW” and then choose the iOS firmware you would like to restore to from the window that appears, and click Open. Step 10: RedSn0w will tell you to connect your device to the computer, so just connect your iPhone to the computer and tap on Ok (Well it is more a click actually but haven’t we got enough clicks in this tutorial?) Step 11: If you are re-restoring the same iOS firmware version, RedSn0w will automatically check Cydia to check if the correct blobs are saved but if you want to re-restore to another firmware then RedSn0w will ask you to do it. Tip: (You can click the Local button to search for blobs and remotely point RedSn0w to the saved blobs on your computer if RedSn0w can’t find the blobs itself) Step 12: RedSn0w will start restoring your device but before that, it will tell you that this procedure will upgrade your baseband so you can press “Yes” to continue or “No” to stop. Press “Yes” and RedSn0w will start the restoring process. Step 13: RedSn0w will automatically inform you when your iPhone is restored. Step 14: And Voila! Your iPhone is now finally restored. Enjoy! |
The Following User Says Thank You to mobilehelper For This Useful Post: |
10-28-2012, 06:15 | #2 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,250 | Thanks-hunting is starting now ! http://forum.gsmhosting.com/vbb/f456...-15b1-1551473/ |
