10-02-2012, 21:20 | #2 (permalink) |
Freak Poster Join Date: Dec 2010
Member: 1461211 Status: Offline Thanks Meter: 27 | Downloaad From Here iphone 4s ios 6.0 Error 3194.rar |
The Following User Says Thank You to nihad_r76 For This Useful Post: |
10-02-2012, 22:55 | #3 (permalink) | |
Junior Member Join Date: Dec 2011 Location: Sarajevo
Member: 1703218 Status: Offline Thanks Meter: 4 | Quote:
Fix Error 3194 The fix is the same regardless of what operating system you are using: Quit iTunes Locate your hosts file, in Mac OS X this is /etc/hosts and in Windows this is c:\windows\system32\drivers\etc\hosts Open the hosts file with Administrator privileges Add the following lines to the very bottom of the hosts file: 74.208.105.171 gs.apple.com Connect your iPhone to the computer Launch iTunes Put the iPhone/iPad/iPod into DFU mode by turning the phone off and then holding down the sleep and power button for 10 seconds, then release the power button but hold onto the home button until iTunes tells you that the device is now in recover mode Use the iTunes Restore feature as usual with the iOS device Once your iOS update is finished, remove the “74.208.105.171 gs.apple.com” line from your hosts file again so that iTunes can properly update as usual. If you need them, you can get iPhone firmware, iPad firmware, and iPod touch firmware directly from Apple. If you are wondering what the IP address is that you are reassociating gs.apple.com with, it’s saurik’s (of Cydia fame) signing server. | |
